Question about John Deere Garden
Mower runs for 10-15 mins. ands shuts off
I can cut for about 10-15 mins. and the engine starts to spit and sputter.If i disengage the blades the it starts to run smooth again for a min. or so then shuts off.
  • 1 more comment
  • josh1111 May 11, 2010
    sound like a safteyfeature somewere is going bad, does it have a saftey shut off on the seat? try jumping it
  • joe May 11, 2010
    if not a safety switch (as mentioned by josh1111), then i would look at overheating. check to see if the spark plug is the correct one for this mower. if its the wrong heat range, then it will act like this.
    if the right plug, then you may have contaminants in the fuel system (gas tank, filter or carb) that might be obstructing a fuel line or carb jet. may require removing the carb float bowl and see if there is rust in there. i have had this on my craftsman lawn tractor to the point where the rust caused a hole in the carb bowl.
  • Anonymous Mar 28, 2014
    After about 20 minutes, will start again and runs for about 2 min
  • 26 Answers
I had the same problem on my craftsman 18.5 hp, the problem was in the choke, the spring was broken, and the choke was not free, replaced the spring and it is fine now. Check it out. Good luck.
Posted on Aug 12, 2012
2 Suggested Answers
  • 3 Answers
SOURCE: Mower runs for 10-15 mins. then shuts off.
I would agree with the gas cap being the problem. There should be a insert inside the cap which helps with the tap pressure. If this is lost then the engine will run for a few min. and shut off.
There is one other thing and that is the float in the carb bowl. It may be allowing in just enough gas to fill the bowl and then it is sticking. This would account for just enough fuel to run for a brief period and then shut down.
VTX Guy
Posted on Mar 10, 2009
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
The 12.5 murray 38 in runs fine until i engage the blades,while engaged the mower runs fine for about five seconds then starts to spit and sputter.once i disengage the blades it runs smoothly again
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Jul 07, 2011 | Garden
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Check your gas cap. There must be a vent for the gas to flow joedog
Feb 26, 2009 | John Deere Garden
Garden Logo
912 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
