Question about Singer 3116 Simple
Feed dog problem.
The feed dogs won't work, meaning my fabric is not moving through the mechine and it is getting jammed. I have just bought this mechine yesterday it is a singer simple. 3116 it looks like the feed dogs are down but I do not know how to fix that problem there is no button or anything please help because I am about to take it back.
  • helpme82 Feb 26, 2009
    i just got the same singer simple for a bday gift and im having the same problem. did you figure it out or was it a product problem?
  • Anonymous Mar 14, 2014
    Feed dogs set too high
    Scholar:
  • 69 Answers
Open the bobbin case door and there should be a lever sitting off to the right. It moves from left to right. For the feed dogs to be in the up position the lever should be to the left.
Posted on Mar 01, 2009
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
I have a JukiLU562 and fabric won't move starting to sew
the feed dogs are what move the fabric thru the machine to sew it
if the feed dogs are not working, then they need to be checked
to see if they have some loose or broken or need to be retimed
Jun 05, 2012 | Juki Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Singer 3116 Simple Logo
633 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
