Question about Jenn-Air JEC9530 Electric Cooktop
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
  • 135 Answers
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Posted on Feb 26, 2009
I've replaced the switch on my cooktop four times. The last time, I replaced the element also and I haven't had any issues...so far!
Posted on Mar 11, 2009
My jenn-air JEC9530 is red light blinking.
you will need a new heating element in and if that dosent work you need a new one
May 30, 2009 | Jenn-Air JEC9530 Electric Cooktop
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Did the element fail, or the switch, or the harness?
Buying and learning to use an ohmmeter is best. You can also inspect both the harness and the burner for damage. If nothing is burnt or broken, then you probably need the switch. Hope this helps!
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JEC9530 Electric Cooktop fan rattles
When I turn a burner on I don't here the fan run. is this a problem?
Dec 12, 2008 | Jenn-Air JEC9530 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Jenn-Air JEC9530 Electric Cooktop Logo
799 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
