Purchased 1/30/02. Not main TV. Cable hookup w/HD box. Nice picture for years, than color began to fade. Red spot appeared in middle of screen. Lost red color completely. Checked all connections and replaced antenna cable which returned the red but orangy color, but color and brightness is still poor. Video adjustments not capable of returning a good picture. Is there a picture tube or bulb that needs replacing, and can I do the work? TV repair service is non-existent in my area. Thanks to anyone for help.
JT
my televisions color is very dull and fading away.is there any way to fix this problem.
If it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
SOURCE: Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
SOURCE: Kines on Screen and Fading
Open up the front of the set by removing the speaker screen and the black piece of particle board. on the bottom right you will see 4 knobs. Turn those knobs slowly till the arcs go away. The 3 knobs on the bottom are for color. the 3 on top are for the focus.
SOURCE: screen not crisp. words are blurry and colors are faded .
you need to replace the coolant in the cRts. You can get the coolant replacement kit at the following link under the repair kit category. Its called phillips CRT coolant replacement kit. It contains all the coolant you need and the step by step proceedur on cd with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: the color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
What do you do if the piture tube on you computer monitor is fading?
