Question about Palm Aneroid Sphygmomanometer By Mdf Instruments Direct, S.Swell
MY SPHYGMOMANOMETER IS SITTING ON 220 AND NOT 0. HOW CAN I FIX IT.
Sphygmomanometer
I take it the device is either auto or manual. If it uses batteries, they may be exhausted. Or, there is a valve that may be open. It looks like a shiny metal thing near the bulb. Or that valve might be defective, and it just doesn't shut properly. If that's the case, it should hiss a little bit.
The hose might not be screwed together tightly. There are inexpensive, accurate wrist cuffs for blood-pressure monitoring that work very well. If none of this works, you might pick up one of those.
Jan 20, 2014 | Health & Beauty
The needle on the Sphygmomanometer gauge will not return to its zero reading. Otherwise it seems to function correctly.
This will happen sometimes, if the BP Cuff has been dropped and the gauge gets stuck. Have you tried tapping on the gauge with your finger, to get it to return to 0 ? Also. be sure the thumb screw air valve is fully open and the cuff is completely deflated. The gauge is easily replaceable, if necessary. Just contact the manufacturer of your BP Cuff or if you prefer Sphygmomanometer.
Thanks for choosing FixYa.
Sep 22, 2011 | Lifesource Aneroid Professional...
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
We need to recalabrate the sphygmomanometer...how do we do that?
Hi mindy_blu
thats the problem with sphygmomanometer, however you may try this. open the glass part then try to re align the hand of the manometer. this will then calibrate your manometer.
Thanks
banaple
Aug 30, 2010 | Mabis Aneroid Sphygmomanometer, Large...
"Lumiscope"Sphygmomanometer needle begins on 80 mm/Hg and will not go any lower.How do I get it to go back to "o" ?
to let the needle go back to zero, find the air valve of the sphygmanometer then turn it counter clockwise or clockwise, depends on your sphygmanometer manufacturer.
Aug 11, 2010 | Lumiscope Aneroid Blood Pressure...
The needle is stuck on 120 on my sphygmomanometer
This problem may need to be escalated to a higher repair center a place like a precision measurement equipment lab. With it being a gauge I wouldnt recommend opening or doing anything to it since it is used to measure blood pressure.
Mar 10, 2010 | Palm Aneroid Sphygmomanometer By Mdf...
Scope is stuck on 300
Unscrew the silver ring from around the dial face. Lift off the clear cover. Pull the needle off the pin. Re-align the pointer to "O". Gently push needle back on to pin avoiding pushing to hard or bending the needle. I hope this solution solves your problem.
Jan 28, 2009 | Mabis Aneroid Sphygmomanometer, Large...
Canon CP 220- HELP
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=259&modelid=10073 Here is site for your printer. Try unplugging (from the wall and computer)the printer for a few minutes let it clear out the memory etc. Or even download and install the latest drivers. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Canon CP-220 Thermal Photo Printer
Palm Aneroid Sphygmomanometer By Mdf Instruments Direct, S.Swell Logo
90 people viewed this question
Top Palm Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Palm Health and Beauty Expert? Answer questions, earn points and help others
