Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
EPSON STYLUS C90 CISS INCOMPATIBLE CARTRIDGE!!
I have an epson stylus C90 with CISS and it cannot print cause it says cartridge incompatible but when i replace it with original cartridge it shows the same problem cartridge incompatible...pls help
    Sergeant:
    Champion:
  • 357 Answers
The cartridge may be defective, as I seen this numerous times, try buying another cartridge from a diffrent retailer and make sure the tape is removed before installing the cartridge.
If this works, you can contact Epson if it is there OEM cartridge that is defective for a refund or replacement.
Good Luck.
Posted on Feb 26, 2009
My Epson Stylus T13 Print One Color Only. Why?
If it cartridge is an old one then most likely low or out of ink.
Mar 19, 2013 | Office Equipment & Supplies
Changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 24, 2010 | Epson Stylus cx7450 All-In-One InkJet...
In Epson Stylus C43SX InkJet ,both led s are constantly glowing.Online printout is not coming.pls let me know the reason.
“All lights/leds blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
Dec 08, 2009 | Epson Stylus C43SX InkJet Printer
I have an epson stylus sx115.It comes up with incompatible cartridge even when I put the orriginal cartridge back in.Why is this and what can I do?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Incompatible cartridges
cartridges maybe bad. Take the cartridges out then put them back into the printer. Turn the printer on and off. you can also get the ink pad reset utility from epson.com if that does not work.
May 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson r220 printer problem
try replacing the black ink cartridge with a genuine epson cartridge.
Aug 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,509 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
