Question about Apple Final Cut Pro 5 for Mac
Audio tracks When i uploaded my footage onto final cut, the audio is only coming out of one speaker. How do I change it so that it comes out of both?
  • dancinqueen4 Feb 26, 2009
    Well it is uploaded onto final cut. SOme of the clips has audio coming out of both speakers, and some only have the audio coming out of one.
    Is there a way to change all of the sound to stereo through post?
  • 121 Answers
Did you check to see if the hardware in your computer is compatible with that software? Sounds as if you have a sound card that isn't compatible with the software. Check Media player to see if you get sound out of both speakers, if you do then it could be compatibility issue.
Posted on Feb 26, 2009
  • Garrett Murray
    Garrett Murray Feb 26, 2009
    Well sounds like some of the clips where recorded with Mono sounds and some with sterio sound, that would explain why you only get sound out of one speaker some time.
  • Garrett Murray
    I am not possitive but I would say their sould be software out there to do that thought the sound would sound extremely bad.
After uploading all my musci on to my mp3 player when i go to play my music and the albums without track names that are just named track 1, track 2, track 3, and so on are out of order because they are...
You can copy these tracks back onto your computer, delete them off your MP3 player.
Rename each track to the song name and then copy them back onto the MP3 player
Apr 09, 2011 | Coby MP620 MP3 Player
How do you record without sound
There does not appear to be any provision on the camcorder menu, to mute the audio.
As an alternative, I would recommend you connect the camcorder to your computer or laptop (via firewire if possible) and transfer the footage onto your computer's hard drive.
You can then use your computer's Movie Maker application to edit the footage - here you can either remove the audio track, or overlay your new audio soundtrack.
Good luck !
"if this has helped you, please rate this solution"
Dec 03, 2009 | JVC GZ-MG330 HDD Camcorder
I put some hd footage onto a blu ray-re disc from one shoot then i shot some more then i tried to add that to the same disc but a box keeps coming up saying disc is not empty it seems as though the disc...
If you have finalized the disk, then there is no way to add tracks or sessions to this BRD.
You need to use a new blue ray disk, and to add original recordings to the new disk.
Nov 04, 2009 | Panasonic Video Cameras
I have to keep rendering after every little edit in final cut pro
I found a video online that helps with this problem. It might be due to your render settings. Also, some edits do in fact need rendering, some edits do not. Take a look at this video and I hope it solves your problem:
Apr 05, 2009 | JVC Everio GZ-HD7 Camcorder
Video8 tapes upload to computer
You need a capture card or firewire output in your camera (This is faster) these capture card bring a software also for editing. If firewire, there is Premier Pro for PC or Final Cut for MAc. Make sure you have the right output connector on your Camera.
Nov 27, 2008 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Sony DCR-TRV230E (how can I upload footage onto my pc?)
You need Picture Motion Browser software CD (came with camera) installation on PC and use iLink port on camera and in PC (IEEE1394) cable to upload footage in PC.
See IEEE1394 cable here.
Nov 26, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
DV In flashing when plugged into computer
Dear njfire,
Test or change your cable !!
(Cable is IEEE 1394 and/or Firewire and/or I.Link, 4-4 pin)
May 19, 2008 | Canon GL2 Mini DV Digital Camcorder
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
if it's .mod files format, you can use mod to final cut express converter
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Apple Final Cut Pro 5 for Mac Logo
53 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
