Question about Kenmore 46462 Front Load Washer
Filter cap on the kenmore front loading washing machine how do you unscrew the filter cap?
  • 10,865 Answers
Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
remember "left is loose, right is tight. So turn it counterclockwise. It will require some strength or a channel lock tool.
Posted on Feb 26, 2009
We saw water leaking out of the soap compartment at the top of the washer, close to the end of a washing cycle. What could be the problem?
access the service panel usually at the front on the bottom or back, and unscrew the round cap that contains the filter/strainer and make sure it is not blocked. Sounds lie it is restricted causing slow drain.Please let me know if this helps
Jan 20, 2011 | Kenmore Front Load Washer
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Mar 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore front load won't drain
Try this, on the access panel below the door(panel that goes across the front of the washer) remove the attaching screws at the bottom corners and pull the panel off, you should see a round,white plastic cap with finger hold bar across the middle of it, unscrew the cap by turning it counter clockwise, pull it towards you to open the trap,clean the filter trap out completely and reverse the order you took it apart to put it back togrether, try running the machine as normal. Good luck and Happy Holidays!
Dec 24, 2009 | Kenmore 46462 Front Load Washer
It will not complete the cycle and gives the message F-21
Hello F21 indicates long drain. You should remove the panel below the door and behind the door you will find the pump. Built into the pump there is what looks like the gas cap to a car. unscrew this gas cap and clear the debris from the drain filter (gas cap) this should solve your problem. Mike
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite HE3t
Take the front panel off (it's simply three hex screws along the bottom and a nudge upwards that do the trick), unscrew the cap to the pump filter, have a bucket handy for the torrent of water behind it.
This will expose the Pump Inlet Strainer.
Front-load washers have this design flaw. You'll be surprised what you'll find in there - panties, missing socks, nylons, hairballs, coins, legos, etc.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
Feb 26, 2009 | Kenmore 46462 Front Load Washer
My intello washer stor working after it pumps the water out on the first cycle
First plug off the wall. This is actually for the Kenmore Elite, but it should help.
You have to check your filter to remove blockage. Lift the machine at front to have access to 3 torx screws under the front panel. Slide downwards out. Have a wet vac ready. You will see the pump filter right in front. Gently unscrew, water will begin to drip, use the wet vac. Remove the cap & pull the filter out to remove all debris & lint, make sure there is nothing in the impeller. Refit carefully.
Feb 20, 2009 | LG WM-2277HW Front Load Washer
Washer machine kenmore
Your filter &/or pump could be blocked. Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
Jan 23, 2008 | Kenmore 43142 Front Load Washer
Spins very slow on rinse/drain and spin
Jan 20, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Robert Rankin
