Question about Iwill KK266Plus Motherboard
I have an AMD KK266-R and need USB drivers so I can use my USB
I just need the USB drivers for a KK266-R board with the Duron chipset.
Thanks
Frank
  • Thomas F. Schneider May 11, 2010
    AMD doesn't make mother boards. AMD makes processors./ Other make mother boards with an AMD socket for AMD CPU's.
    You have an AMD Duron CPU and /or chip set. What brand motherboard do you have?
  • Richard Ray May 11, 2010
    hiya
    usb driver for what exactly.....and which version of windows are you running
    Guru:
  • 417 Answers
Go & download then install driver robot : http://driverrobot.com/download/
When it's done open the application & click on the "EXPORTER" from the list on the left hand side.
Select were to save i.e Desktop or My Documents, Driver Robot will then run a scan & save the results to the file you specified it to save to i.e Desktop or My Documents.
Then go to the saved file which looks like a web document & double click on it,then you should see a page with "Get Drivers" on it. Press the "» Get Drivers" link in this page to proceed to the drivers list
You now have access to the hardware scan results and all available driver updates for your machine.
Posted on Jul 05, 2010
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Problem in my mother board
just visit this location. it has all the drivers.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=264&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Apr 22, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
No I didn't...I still need USB sys drvrs. for my AMD kk266-r MB Duron chipset, Win2K Pro is the OS. My @ USB ports on the back of the computer don't show up in the device manager because there are no...
you can download a device driver for your USB Device on Microsoft website:
http://support.microsoft.com/kb/819332
although it is available on the Service Pack 4 of windows 2000 professional.
or if you have your mainboard cd it must be included there.
Feb 26, 2009 | Iwill KK266Plus Motherboard
Tech spec
This board came out in October 2003. From the Chaintech tech specs:
  • Socket A for AMD Athlon XP / Duron processors
  • AMD Athlon Processors up to 1.4GHz
  • AMD Athlon XP Processors 1500+ to 3200+
  • AMD Duron Processors up to 1.3GHz
  • Hope this helps & please rate this solution fixya. Thanks.
  • Feb 05, 2009 | Chaintech 7NJS-ZENITH Ultra Motherboard
    Sound Driver for AMD Duron 756
    hai have amd duron process pc but i want mother board drivers
    Jun 15, 2008 | Computers & Internet
    Upgrading processor to Duron 1.4GHz
    well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
    Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
    you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
    also make sure the motherboard can actully take a higher processor.
    Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
    Good luck
    Jun 04, 2008 | ASUS VIA KT133A Chipset A7V133-C...
    Will these work together?
    Looks like a match to me. Except for the very highest end processors in the socket A line, all socket A processors should work in any socket A mainboard.
    Feb 16, 2008 | Biostar computers10: Main Board...
    FOXCONN K7S741GXMG-6L
    AMD 2800+ is 333MHZ while
    AMD DURON 120MHZ is just 200 MHZ
    It means that the board supports 333MHZ not 200MHZ.
    Well it's not compatible...
    Jan 27, 2008 | Foxconn K7S741GXMG-6L Motherboard
    JetwayV266b (REV: 3.00) - Max processor speed??
    Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
    Sep 17, 2007 | Jetway V266B Motherboard
    Iwill KK266Plus Motherboard Logo
    229 people viewed this question
    Top Iwill Computers & Internet Experts
    Alun Cox
    Josh Whitehead
    Josh Whitehead
    David
    David
    Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
