Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
On the front of your cdrom by the power button there is a small hole. Take a paperclip straighten it out slide it in that hole directly in the center and push slightly don't force the door will open when you push on the release button with the paperclip.
Terry
take a paper clip and streighten it out in a long wire - you should see a hole in front of the cd rom by the drive bay press it in the hole and push the drive open
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Vista has identified your printer. It loads up its default printer driver (stored in vista OS) in your new computer. This usually have the basic features only. You need to run again the CD to install or enable the added features of your said printer. If you have lost the CD you can do an alternate option by downloading the software on this link. ftp://ftp.hp.com/pub/united-states/pse/hppse1.12.0.46enu.exe
For the the CD that was crumbled inside your cd-rom. You can try to pull out the CD from the Tower casing and try yo maually open the CD rom unit itself. Or may i suggest that you can buy a new one. (CD/DVD roms are cheaper now a days)
The causes of CD crashing inside your CD rom;
1. wrong placement of CD/DVD disc 2. Hardware failure of the CD/DVD roms
i had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
