Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Jucuzzi era bk 37 959 just installed 6 weeks ago , I have to use
Use a plunger three or four time a week because it stops up sometimes when only a little paper is flushed, i have never had a tolet that was the much trouble........
  • 547 Answers
When it was installed the wax ring was most likely installed wrong or has moved and is blocking drain it cost 5 or 6 bucks to replace. thank you for for useing fixya please rate me
Posted on Feb 26, 2009
We have a propane tank outside to supply our range stove in the house for some reason the gas is not reaching the stove anymore , can it be the cold weather?
I would suspect the regulator might have iced and maybe if you poured hot water over it it would pass on thru system but be prepared to buy a new one if it doesn't .
Jan 13, 2015 | Cars & Trucks
Four litres of fluid removed from my friends lung in three weeks
I would get a second opinion from a lung specialist.
Sep 19, 2014 | Cars & Trucks
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
The blower works but there's no A/C
freon level may also be low. Once the level is low, a low pressure switch will open the circuit to prevent the compressor from running and burning up.
Jun 17, 2009 | 1998 Oldsmobile Aurora
Mybook keeps stopping
I had the same problem. For about three months after buying the unit, I had to power-down and restart three or four times a day. After installing XP on the only Vista computer in my four computer home network, the device has not failed once. That's been for a week now. By the way, I don't use the Mionet software.
Apr 15, 2009 | Western Digital 500GB My Book World...
My xbox 360 just grinded my brand new Rockband 2 disc.
The Xbox 360 is known for this. I would contact Microsoft as soon as possible.
Assistance by phone seven days a week.
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102 Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Jan 02, 2009 | Microsoft Xbox 360 Console
1997 Pontiac Gran Am Key problem
There is a solenoid & plunger next to the ignition switch inside the steering column that stops functioning. The plunger must be retracted in order for the switch to turn all the way so the key can be removed. manually insert the plunger and take out the key.
Nov 05, 2008 | 1997 Pontiac Grand Am
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
201 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
