Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak replaced esp-3 today and installed and the same problem exist: both ink sensors are red, replaced with new, but the same problem, also the window flashesE, need help. Merle
  • idreamahiway Mar 11, 2009
    We have had the same problems that everyone else seems to have. Kodak has replaced the printer, ink cartridges and print head. The problems keep getting worse. What has happened to Kodak???????????????/
    Problem Solver:
  • 8 Answers
Try calling kodak support. May need a new print head
Posted on Feb 26, 2009
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
ESP-3 printer does not print yellow component. This happened from new and is not affected by changing the ink cartridge.
Try to reinstall the printing software once again with the CD provided, if the problem exists call the customer care to sort out.
Thank you.
May 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I was troublshooting my ESP 5 with two new ink cartridges when they told me they would have to send me a new printhead. The new printhead is here, but when I install the cartridges (again and again with...
If the cartridges were out of the printer in the open air,they might have gone dry. Try to reseat cartridges 2-3 times,if isssue persists,get a new colour ink as Kodka will certainly not replace the ink for you.
Dec 10, 2009 | Kodak ESP 5 Printer
Kodak ESP3 printer flashes red light under color ink. Kodak tech said I needed new printhead. Send one and I installed it but have the same problem.
try replacing the ink cartridges with genuine Kodak ink cartridges and if still does not work call kodak tech support as it will be a printer hardware problem......
Jun 17, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I need to change the printer head on my Kodak 5100 all in one printer
To install the printhead and ink cartridges in the: Additional search terms: print head, tank, replace
Jan 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Replacing printhead on Kodak 5500
Jan 20, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
44 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
