Question about Dell (313-3460) Cable Modem (W8378)
MODEM FOR DIAL UP
DO I NEED TO INSTALL A DIFFERENT MODEM TO MY COMPUTER IF I AM GOING TO DO DIAL UP
  • 102 Answers
Well do you use high speed now/ like Dsl or cable?
if so your hooked into the nic card..with a cat5 cable look on the back of you computer and u should see a modem. should have a 2 phone jacks ..one is for a phone to plug in and the other is for your phone line for dial up... if you dont have this ... then you have to buy 1 maybe 10 to 15 bucks at walmart they are easy to install....
Posted on Feb 26, 2009
Where does a dial up modem go in a Dell optiplex 760?
The dial-up modem would install inside the computer in a PCI slot. VERY easy to install but a couple considerations before doing so... There are different sizes depending on whether the OptiPlex is a mini-tower or small form factor case. Also - you would need drivers for the modem that are compatible with the operating system you have installed on the computer.
Apr 28, 2014 | Dell OptiPlex 760 MT Desktop Computer
Tip
Linking your system connection to Air
TEMAB COMPUTERS ICT
You moving to the world of internetworking, as in you connecting your system with a dial up or modem so you can access the internet from your home, office and everywhere you may be the following are to be considered .
1. A computer. In order to use dial-up you must make sure not only that you have a computer but that it is going to work with your dial-up service. Some ISP's do not require that you install any software to get connected, so just about any computer would work. However, if they do require that you download their software or run a CD to start their service, you need to make sure that their software is compatible with your service.
For example, your computer may not have a CD drive if it's a compact laptop. Or perhaps you have an older operating systems like Windows 95 or 98. Many installations are not compatible with these older computers. If you have a Mac or Linux computer, you must make sure that the ISP will be compatible with it, or it might not work. If you are using the modem that came with the computer you have to make sure that the modem is installed or updated enough that it will not cause slow connections. Check with a computer technician if you are not sure there is a modem or that it's in good working order.
2. A modem. If your computer does not have a modem, or you wish to use a separate external modem, make sure that it is the correct type of modem. It must be a dial-up modem--broadband modems will not work. Also make sure that your modem is going to be compatible with the services you would like to have on your dial-up. For example, if you would like to add an Internet Call-waiting feature on your dial-up service, you need to have a V.92 standard computer. Otherwise you will not be able to be notified of incoming calls while you are online. Also, if the modem is not in proper working order, for example, it is missing it's latest driver software or has been damaged or corrupted, you will not be able to use it. Thirdly, if the modem is too old and does not have the latest standard, it may not connect as fast as a new one would, so if you know your modem is not V.92, you may need to get a new one so you can get better connection speeds.
3. A land-line telephone. This means your phone line must be an analog phone--cable phones, digital phones, and (usually) cellphones will not work. Dial-up uses analog phone lines because of how it converts and transmits information. It's just like a normal telephone. If you try to use dial-up on any other type of phone, you will get an error connecting because the modem cannot detect the analog dial-tone. Check with your phone provider if you are not sure if it is compatible to dial-up. Also, keep in mind that you will not be able to use your phone and the Internet at the same time, so if you wish to keep your phone line free for telephone calls, you may need to add a second line to your home. However, if you don't want two lines, simply add call waiting and caller ID to you land line and if you have a V.92 modem, you should be notified of incoming calls while you're online.
4. A telephone cord. This may sound silly, but some people do forget about this step. In order to have Internet through dial-up, you must have a phone cord attached from the back of the modem or the back of your computer to the phone jack in the wall. You might want to get a splitter so your phone line can share the phone jack with your computer, or you might be able to connect your computer to your phone or vice versa, using the "line in" and "line out" jacks on the phone or on the back of the computer.
Another important thing to keep in mind is that your telephone cord needs to be as short as possible. Any cord longer than 6 feet could affect your ability to connect to the Internet, or affect how fast you can connect. The longer the cord the more likely you are to have slow or dropped connections. Also, you may need to get a back up phone cord in case the cord you intend to use is damaged. If you buy a new modem, an extra phone cord is usually included.
After all that then you can move to meet an Internet service provider to have their modem or dial up. and their setup for the dial up giving to you. From there have a wonderful browsing and meting people
…………………connecting yourself Globally……………………………………
TEMAB COMPUTERS ICT
on Apr 30, 2010 | Computers & Internet
It is creating an erroor 651
  1. Go into My computer > control panel > modems.
  2. Check correct modem is installed. If not then remove modem > restart computer > re-install modem.
  3. If still getting the same problem > go into control panel > networks > remove dial up adapter and TCP/IP > restart computer
  4. Go back into control panel > re-install dial up adapter and TCP/IP.
  5. Advise customer to get latest modem drivers.
Apr 22, 2011 | Office Equipment & Supplies
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
Sep 27, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
I have a dial tone, but will not dial .I have a HP Pavilion computer and use a dial up service. I delt with HP on this 4 months ago and they sent me a new modem, and curred the problem. Now the problem has...
If it is a USB modem, connect it to a different computer, and try it.
If it fails to connect, with _two_ different computers, then the problem is in the modem, not in your HP computer. Give that information to HP.
Or, switch to high-speed "lite" (as in "lite beer"), for about the same amount per month as for dial-up, and throw the modem away.
May 13, 2010 | HP (56K V90 USB) Modem
Internet connection
Depends on your system, install modem first then the system should ask for drivers. Make sure your dial up modem drivers are appropriate to your operating system. Try the modem in a different slot, some modems are not compatible with some motherboards. If the My Computer/System/Device Manager can't see the modem, you have to try another modem or slot. Then install or Update drivers once the system sees it and will show Properties of it.
Aug 19, 2009 | Compaq (198721-001) Modem
Connection a Netbook to dial up
if your netbook doesnt have built in dialup modem that mean u cant connect it to a dial up connection. most of netbook in market use wifi as primary connection or sometime comes with built in GSM modem to connect to internet. that meanc the option you can try is to buy a external USB dial up modem
Mar 26, 2009 | Advent 4211c Notebook
I bought my modem at my local walmart in August of 08. Now the modem cannot detect a dial tone. I have had it at two different houses to make sure that it's not my phone line and it is still the same. I...
you might need to contact a computer technician because if it has no dial tone means, your are not installing the modem correclty (if modem is good).
Oct 20, 2008 | Gateway Computers & Internet
No dial tone
and does your line to your computer have one of the filters installed going to your modem line?
check your computers warranty here 4 FREE
Mar 18, 2008 | Symantec WinFax Pro 10.0 for PC
Dial-up: Internet Connection
do your pc have a dial-up modem card?
What's the brand? Go to download the latest driver for the modem and try and see.
If not, right click on my computer icon, go to hardware tab, select "device manage", see does it detect any modem driver or not.
If after installing the driver still the same and can't be detected, most properly your modem is going to "heaven".....
Try to change another modem, see whether it can work or not.
Dec 14, 2007 | Computers & Internet
Dell (313-3460) Cable Modem (W8378) Logo
161 people viewed this question
Alun Cox
