Question about Sram Cycling
Chain rubs inner front derailleur while in lowest gear.
I changed compact cranks to standard. SRAM Force crank with 11-26 SRAM cassette, all other components are Dura Ace. Chain rubs inner front derailleur, small on big 3 lowest gears. With current adjustments I can no longer shift for 1/4 out to adjust for high gear chain rubbing. Is my problem the mismatch of componets? My bike is a Trek Madone 5.5 size 50.
On front derailleurs there should be two small cross head screws one has L(lower) next to it the other has H(higher), you will need a cross head srewdriver, you simply losten or tighten the 2 screws and it will adjust the position of the derailleur to your crankset and it that completely fails then you might need to try a different crankset
Posted on Mar 05, 2009
On my ROAD bike could a Sram/Truvati XX or XO (crankset 42/28-cassette11/36) work smoothly with Sram red doubletap Thank you.
To use Sram Red Shifters with such a wide range rear cassette requires a Sram 10-speed MTB rear derailleur such as an XX or X.0, it will work without problems with your red shifter.
Because it is a road bike, i suggest leaving the road crankset and front derailleur in place. If you need low gearing I suggest a compact front crankset.
If you need to use a mtb crankset, attept to use the road front derailluer with it.
Mar 11, 2011 | Sram X-0 XO REAR DERAILLEUR MTB ATB LONG...
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 | Cycling
Gears not changing quickly enough. and then changing 10 to 15 seconds later after clicking shifter . when they eventually change they seem to thud down the cassette . no promblems putting them back up the...
Two things to this problem.
1. Clean your drivetrain REALLY, REALLY thoroughly with a good degreaser and a bristled brush. All of it. Clean the derailleurs, the chain, the cables. Once it is all cleaned up and dried off, lubricate the chain and the cables ONLY.
2. Shift your bike into the highest gear and release the cable. Pull it taut and re-tighten it. Flip it over and shift into your middle cassette cog while cranking the pedals. Use the barrel adjuster on your rear shifter to get the jockey wheel on the cassette aligned over the correct cog.
This was an abridged guide to rear derailleur adjustment because it sounds like it was more grunge in the cable or derailleur than anything else, but i'll check back and if this solution doesn't work out, i'll give you tips on a far more thorough overhaul. Just remember a clean drivetrain is a functional drivetrain, and the cables and chain are the only thing you are supposed to lube.
Hope this helps,
matt
Sep 16, 2009 | Sram X.9 Rear Derailleur
What is the adjustment procedure on a shimano deor front derailleur. it will not shift into high gear.
Try this first:
Shift into the small ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your shifter. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Sep 04, 2009 | Shimano Deore LX Mountain Bike Front...
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Sep 02, 2009 | Cycling
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
709 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
hgpilot
John Egan
John Egan
Are you a Sram Cycling Expert? Answer questions, earn points and help others
