Question about JVC AV-27530 27" TV
No sound tv work great comes on no sound i checked speakers they work..can this be fixed
  • Rob McCutcheon
    Rob McCutcheon Mar 12, 2009
    YA THEY ARE SWITCH ON THE SOUND CRACKELS IN AND OUT SOME TIMES IT`S THERE AND OTHER TIMES IT GOS OUT
  • jpb1974 Apr 06, 2009
    I have a perfect picture but NO sound (no white noise, nothing) , it's not muted, any ideas??
  • 89 Answers
Sometims the speakers are switchable in the menu, make sure you have them switched on
Posted on Mar 12, 2009
Toshiba 32" regza TV great picture but no sound how can I solve this please.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 14, 2014 | Toshiba REGZA 47HL167 TV
I have the same problem with my 3 year old Dell 32 inch Tv
Yesterday I went to the pawn shop and purchased a Sony receiver they just got it in a couple a days (pawn shop) ago. The receiver is in great shape still had the stickers on them for less than 100.00. We hooked the speaker and the cords black/yellow/red to the in/out in back of the TV and the receiver. Wow! Great surround sound and the TV works like new. Please do not go and buy a sound board you will be wasting your money and the same thing will happen again and again. Dell sucks!
Jun 14, 2009 | Dell W3201C 32 in. LCD Television
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
Aug 15, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba 32A33 no sound
your tv needs to be open,check the speaker if its good or not ,then the supply of the amplifier and the amplifier itself also.
Jul 25, 2008 | Toshiba 32A33 32" TV
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Pic but no sound!!
If it's still under warranty you can get them to come fix it.
or if it has a speaker/audio out jack in the back of some nature you can stick speakers on that way...
Other than that the last solution I can think of would be to find aftermarket or similar speakers to replace the ones inside if the speakers blew... but we don't know if the speakers died...
Jan 31, 2008 | Samsung HCM5525W 55" Rear Projection...
Sound problems
Make sure it is not a problem with the DTV reciever first by connecting up another smaller TV set to that reciver. if it is the TV set for sure, a cheap fix would be to run the audio outputs of the DTV reciever to a small stereo or a powered speaker. Good Luck
Mar 23, 2007 | Sharp 27H-S60 TV
JVC AV-27530 27" TV Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
