Question about Whirlpool GEW9250 Electric Dryer
Dryer continues to run....
I have a whirpool GEW 9250 Dryer..The dryer starts running every time the door is closed...Even if there are no other lights on..I tried flipping the breaker to reset, but still doesnt help...Any suggestions??
  • 547 Answers
Change controls you can find here http://www.partstap.com/ please rate me
Posted on Feb 26, 2009
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer wont start pushed control on button but no lights will come however i do have a light inside the dryer this is a whirlpool 9250
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 14, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer will not run
It sounds like you have a bad door switch.
Aug 11, 2009 | Dryers
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Dryer continuously runs- and starts when you close door
ok, make sure to test the door pressure switch for its operational value. if the switch is in good condition and it doesn't appear to be faulty and, the wires are connected firmly, replace the timer/control. In most cases,your door switch will need to be replaced. these switches will develop shorts overtime.
Jun 07, 2009 | Maytag Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
