Question about Acer TravelMate 4200 Notebook
Wireless only available when powered by intergral battery
Wireless internet connectivity lost if plugged into power supply.
Nearly 2year old laptop computer - ACER laptop TravelMate 4200.
updated with latest drivers via Windows updater but no improvement.
  • 1 more comment
  • laserrick Feb 26, 2009
    How can it be a bad power supply? My power supply tops up the battery, it is working fine and everything else on the computer works as if power supply is A OK.
    Wireles is available only when on 'battery ony' mode,
    Yes! I just created a new acer management power management routine, it included wireless ON. Now I am happy.
  • Thomas F. Schneider May 11, 2010
    My guess ; bad power supply?
    Novelist:
  • 121 Answers
Did you double post this question? I think you might have a hardware profile set up not to turn off wireless when in plug mode. If that isn't the case look in the BIOS and see if there is a setting in there. You could also check the power settings on your laptop.
Good luck,
Armymason
Posted on Feb 26, 2009
  • Garrett Murray
    Garrett Murray Feb 26, 2009
    Awesome glad I could help. Take care.
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
Breaker box went out where wireless router is plugged in and when we turned it back on, the HP notebook pavilion g7 won't connect to wireless. Message says the computer settings don't match t
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Dec 29, 2012 | HP Pavilion G7-1227nr Notebook 4gb Ddr3...
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Hi My daughter droped the battrey off her notbook and now she cant get on the internet, but its detected the wireless conection
there is no problem with the battery in terms of the connection. Battery only supplies power to turn on the laptop. if the battery has malfunctioned and wasn't able to turn on your laptop, you can use your laptop's power cord.
the issue here, is that you can connect to the internet. all she needs to do, is go to Network Connections, chose the wireless connection, clicked Properties, scrolled down to Internet Protocol (TCP/IP), go to Properties and changed the setting to 'Obtain an IP address automatically' then applied the changes.
Feb 20, 2011 | Advent Netbook
Acer Aspire 3610 does not recognize wireless internet connection is available when it is running on battery alone. Plug in the AC cord and it recognizes wireless is available but then takes forever to...
If you are running windows vista or windows 7 then you need to go to the power setting on the system, in the advanced options and look for wireless power setting. Turn the when on battery setting to leave the wireless card running instead of turning it off.
Go to display settings, screen saver, power options, balanced power or power saver, and look in there for the wireless adapter.
Sep 20, 2010 | Acer Aspire 3610 Notebook
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
How to make use of the wifi to get connected to the internet ? My sony Vaio vgn-fw21l has intergrated wirelessLAN Type802.11a/b/g/draft n
You need to have your own wireless router or basically your computer needs to see a wireless signal (any unsecured or secured network around the area). For XP computers, you can go to the control panel and look for network connection and then look for wireless network connection. Right click the wireless network connection and click on view available wireless network. If your wireless card has its own utility, you may have to use it. For VISTA, go to the control panel and click on network and sharing center, click on the manage network connections options at the left hand side and then right click the wireless network connection and click on view available wireless network. If the wireless network that you are trying to connect to is secured. You may have to enter the wireless network password for you to be able to get online.
Feb 25, 2009 | Computers & Internet
Does NEC VERSA LX laptop computer support wireless internet?
This is a pretty old laptop about 10 yrs. It does not come with wireless support. It probably has Windows 98 installed on it.
You might be able to set up wireless via the USB port.
Here are the specs
May 03, 2008 | NEC Versa LX Notebook
Hello I am sorry you r having this problem, I need to know a little bit more info, Now when you plug in your computer to power cord you loose everything with you internet connection. Do you see the active monitor in the lower right hand side, it would look like a monitor blinking or it may not be blinking. Have you also tried to activate the antenna after you plug in your power cord. There should be a button with an antenna on it the upper part of the pc, You may also go into your control panel and turn it on there, It sounds like its set to shut down the wireless connection when plugged in, its just to opposite as what it should be, usually its when you unplug your computer that the internet connection is lost for power saving reasons, you can also right click the connection monitor in the lower right and properties and repair after the power is plugged in of course give that a try and see if that works for you, I hope it help you out with your problems
Jan 15, 2008 | Acer Aspire 5100 Notebook
Acer TravelMate 4200 Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
