Question about RCA HD61W66 61" Projection HDTV
61 RCA Screen Problems
I just purchased my TV a few days ago, It is an 61 inch RCA LCD HDMI TV. I am having a problem, while watching TV the screen will go black and the blue power button blinks on and off about 5-7 times, the sound will stay on, but the screen will display nothing, and it does this for all components and HDMI. I don't know what to do, or how to fix it!
  • RCA Master
  • 8,457 Answers
This is a bad sign of video board backlight going to failure.Make sure u get a warrenty repair,make sure they replace video backlight board.Or exchange the tv.U got a bad IC U could call the CPU for the board.It have intermitent ground sort.U can unplug the power,replug the power,it will work,but this temporally fix only.The high power of the board will kill the IC sooner or later.
Posted on Sep 15, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
I bought a LG 42LB1D LCD tv about 5 years ago.I hardly watch this tv. When i watching dvd few days ago all of a sudden i see only BLACK screen sound is OK and remote control is not consistent sometim
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 11, 2014 | LG 42LB1D 42 in. HD-Ready LCD TV
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
Picture keeps alternating between HDMI1 "blank screen" and cable
try the lead in another slot and even another lead, if problem persists demand an engineer comes out.
Jul 31, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and
Feb 23, 2009 | Mitsubishi WD-57731 57" Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA HD61W66 61" Projection HDTV Logo
163 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
