FixYa.com
Tags:
ASUS WL-100G 802.11g/b Wireless Adapter
Problem getting IP assigned
By Gary10 - usenet poster
Hi all,
At startup, my computer doesn't get an IP-address assigned. Signal is
perfect, but I don't get IP. The other computer WAS fine, but after resetting
an reconfiguring the router, now has the same problem.
Over a broadband internet connection, I have a Motorola modem and a D-Link
router, meant to connect two laptops (both XP) to the internet. The router is
configured for dynamic IP delivery, and is secured by WPA-PSK. My computer is
protected by AVG Free Antivirus and Sygate firewall.
Sometimes 'repair' in the pop-up menu of the taskbar icon resolves the
problem, but mostly only after switching off the power of modem and router or
eventually after connecting wired. Wired connection most of the times is no
problem.
I tried already a lot of standard procedures (resetting modem and/or router,
cloning MAC adress, ...) with no success.
Can anyone help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Melissa
Melissa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Well,
It's not so bad - at least the comp is registered on access point (router),
the only thing which doesn't work is TCP/IP :-)
The only thing I see is checking WZC (if disabled) and then starting again
from simpliest to more complex...
Thx
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Hi
Well. in your case it seems that you can not obtain a Wireless connection
at all.
May be this can Help.
My New Wireless does not work - #
Wireless, Basic Configuration - #
Wireless Security - #
Jack (MVP-Networking).
Solution #3
Helpful (85)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
I have similar problem: the environment is 1 Thomson 780 WL router-DSLmodem
plus 2 laptops.
I can't get my ASUS wl-100g PCMCIA card on Compaq Evo to work properly with
my Thomson: I've managed to get the message "Connected" (with WEP and also
now WPA), but IP doesn't work: ASUS doesn't see DHCP server on Thomson;
assigning static addresses also doesn't work. Anyway, DHCP and all the rest
work fine via UTP cable! I've shut down the firewalls (Windows firewall,
McAfee firewall) but no luck.
At the same time, my business laptop works just fine!
I've tried with new ASUS drivers and UTILITY software, but no luck.
Thx for your help,
O.
Solution #4
Thanks for Trying (70)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
I've managed to achieve solid wireless connection with my older Compaq
laptop and ASUS WL-100g WLAN card via WEP, but would like to use WPA.
I've already reinstalled the drivers and utilities for ASUS, but no luck.
After switching to WPA, the link lives tries to go up for a few seconds and
then drops. At the same time, my new Lenovo laptop connects without a
problem via WPA with my AP (Thomson DSL router).
Any ideas?
Solution #5
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
Hi
If you can configure correctly the Router via wire connection and use the
Internet for a while via wired computer, it means that the Internet
connection, the Router, and the basic Network setting of your computer are
OK. There is No need to "play" with MAC cloning or any other settings that
are Not directly involve the Wireless connection from the computer to the
Router. Stay with one computer on the wire connection, and configure the
Wireless for the second computer. Start with security Off, and configure
the Wireless part of the Router through the wired computer. Once the second
computer is working correctly, switch first computer to Wireless too.
May be this can Help too.
Can you Help with these Wireless Adapters problems?
Wireless Adapters
Winbond wireless usb driver
i recently bought a wireless... Answer This...
Wireless Adapters
Asante Areolan AL1611 PCMCIA...
The Asante Areolan AL1611... Answer This...
Wireless Adapters
WMP55G
hi , i am using rhel 5.0. i... Answer This...
Wireless Adapters
Wireless card suddenly cannot...
My Buffalo wireless card has... Answer This...
Wireless Adapters
Ran
no logro bajar los draives de... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
