Question about Dacor Preference RSD30 Gas Kitchen Range
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or other information. Twice in the past we have had an appliance company replace the DA 62692 Oven Control Board. I don't want to do it again, if there is a way to reset the control board. Barry O'Brien
  • 70 Answers
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Posted on Feb 26, 2009
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Oct 17, 2011 | Dacor Ovens
I have a dacor 48"
phone dacor 1800 793-0093
press 2 for parts
they may be able to locate one
Jun 28, 2017 | Dacor ER48DSCH Dual Fuel Range
M y dual fuel GE oven has no display showing it just went blank, but when you open the oven door the light goes on
I had the same problem as devlin50 with my GE duel fuel 918 model.
If you trip the circuit breaker off and leave for one minute before switching the power back on then hopefully the panel will be flashing, worked for me. Worth trying as replacement panel is not cheap, about $220 here in Canada.
Mar 15, 2011 | GE Profile J2S968 Dual Fuel (Electric and...
My Dacor RSD305 duel fuel oven does not work.
you need service
when set the display starts off at min temp
if no heat rise is present it will shut off
check your house breakers first
Jun 06, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor oven heating coil broke on one side
no it wont work and it would probablr run between 200 to 300 dolars give or take a little
Mar 17, 2009 | Kitchen Ranges
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual.
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Electric range control panel dim
They pretty much are what they are. I've seen many failures of this type on dacor wall ovens that result in having to replace the display board, but must admit I've never seen it on their ranges. Chances are thats what you're going to have to do as well. Not what you want to hear, but replacement is probably your only option. Good luck!
Jun 15, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Preference RSD30 Gas Kitchen Range Logo
443 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
