Question about Acer Aspire 1690 Notebook
Acer 1690 freezes when plugged into wall adapter
As soon as I plug my laptop into wall charger, it freezes and I have to shut down manually. This is a problem because my battery only lasts 10 minutes so I dont get any work done switching back and forth! What can be the problem? please help!
  • dove_f Feb 26, 2009
    but wouldn't it be good? I can only use my computer when i'm on the battery. Can't use it when I plug it in. Doesnt that mean the battery is good and the cord is bad? I just bought this cord a few months ago.. it should still be good.
  • jydelanne Mar 30, 2009
    Hello Every body same trouble for French Acer 1690..No screen on starting or friz after few minutes. I have reinstall with a extra blower and now I like to now haw to update with a new Bios I find the new bios on Acer but I do not now how to do that?
    Thanks
    JY
    New Friend:
My acer aspire 5745 laptop battry plug working fine but plug the adapter to hang the laptop and shutdown the laptop to charing laptop
Posted on Dec 28, 2013
    President:
  • 2,692 Answers
Battery has gone bad. Replace the battery.
Posted on Feb 26, 2009
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
My 1690 don't start black screen.
There could be a couple of reason why laptop didn't start-up. Basic: the battery is dead and need to be recharged. Possibly the battery isn't keeping charge and the AC power charge is un-plug from the wall. Leaving the laptop without power. Make sure everything is plugged in and try to power it up. It that doesn't work then it could be the power supply in the laptop it self. Good Luck!!!
Mar 15, 2011 | Acer Aspire 1690 Notebook
My acer aspire 1690 suddenly shuts down randomly. is not an overheating problem I'm sure. I have also been checked by a technician but can not find the solution
Hello, the major reason of laptop randomly shutdown is Overheating, you said it is not over heating...
I will suggest you couple of things that you can try:
1) remove the battery and plug the laptop on direct power supply, then place the laptop on a flat and hard surface and then boot the laptop.
or do a complete virusscan of the laptop.
or reinstall the OS...
Apr 15, 2010 | Acer Aspire 1690 Notebook
I have an Acer Aspire 5050. The charger/adapter
yup your plug receptical in the laptop needs replaced
Dec 11, 2009 | Computers & Internet
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 1690 Notebook Logo
247 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
