Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
My dishwasher will not drain do you think it could be the pump?Or do you think it could be something else?
  • Nikki Nicholson May 11, 2010
    What is the make and model of your machine?
  • 10,865 Answers
There is most likely a blockage in the pump. this is an easy fix. remove the lower front panel and u will see the pump at the end of the drain line. disconnect it and you will find a piece of glass or some other obstruction there. since the dishwasher has water in in u will want to remove the water first with a shop vac or a sponge.
Posted on Feb 26, 2009
My dishwasher is not draining. I think something is stopping it up. Where do I look?
Normally the drain for the dishwasher runs behind the cabinets and ties into the sink drain, just above the trap. So if the dishwasher is near your sink, check there, usually it is a rubber joint there with a hose clamp. Have a bucket ready just in case it is backed up and dumps water, then remove the hose clamp and twist and pull the hose off and check it. If there's no blockage there, then it's most likely the pump went bad in the dishwasher itself.
Aug 11, 2017 | Dishwashers
Samsung dishwasher starts and after while stops with three lights cycles on (heavy , normal and quick)
I think that light combination means "Drain error". Most comonnly caused by something hard getting down into the drain pump, blocking or partially blocking the drain pump impeller or the check valve inside the drain hose right next to the drain pump.
Feb 24, 2015 | Samsung Dishwashers
My previously quiet Asko dishwasher now makes a lot of noise during draining cycles
Hello Beverly;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I have to advise in general terms.
It sounds like your drain pump is struggling.
Clean your drain and/or drain filter. Wear gloves you may have broken glass or something sharp in your drain.
You garbage disposal line may be plugged.
Or you drain pump may be going bad (But, I do not really think so).
Dec 22, 2014 | Asko Dishwashers
De longi dishwasher wont drain
I think you need to remove the drain pump and get the waste collected flushed out. Please check this link for tips to remove the pump and clean. Make sure you take care to switch off the power while working.Finally check for the level of the machine to be slightly inclined towards the drain outlet.
Click on drain
Jun 25, 2013 | Dishwashers
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
The water does not pump or drain out after the wash is done
you have something stuck in the pump i think.maybe a sock or something. try looking at the the pump....its clear so you should be able to see if anything is stuck in the or use a wire hanger and get up in there and pull out whatever it is thats in there
Jan 08, 2009 | Admiral 24 in. DWUA651 Built-in Dishwasher
Kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
May 03, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Water isnt draining
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
Apr 29, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
