Question about Brother HL 5250DN Laser Printer
Brother HL-5250 DN - Drum Replacement Problem
I just tried to replace my old drum (which I've had for 3 years) with a generic drum, purchased from Concord Supplies. Replacing the drum was fine, but after the replacement, print quality became extremely poor. Letters have lost most of their thickness and thin lines are not even printed. Everything just looks faded.
Did I do something wrong? Is there a setting I need to change? Or is this just a bad drum?
Switching back to my old drum, I get much, much better print quality.
  • Anonymous Mar 19, 2014
    HAVE REPLACED DRUM BUT PRINTING IS BAD
Try a new toner, if its still a problem then the drum is a dud. I've had dud generic drum's before.
Posted on Mar 16, 2009
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
I replaced the drum in my HL-525-DN because the drum light was flashing slowly. After putting the new drum in the machine, I held the "GO" button until all lights were lit up and then pressed...
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press and hold OK for about two seconds to display Drum Unit, and then press OK.
  4. Close cover.
Nov 06, 2017 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
My hl 5250 dn printer is printing a wide horizontal line on the leftside about 1/3 way in. How do I fix?
The problem mostl likely is that the handle for cleaning the corona wire isn't at it's start location. You can fix this by simply open the machine, unmount the toner/drum package and move the corona cleaner (the blue/green/grey marker) on the drum unit to the start position so the two arrows face eachother. This should solve the problem.
Jun 08, 2009 | Brother HL 5250DN Laser Printer
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
HL 5250 dn
first you most clean the printer carefully then you most change the drum unit
Feb 28, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
1,210 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
