Question about Whirlpool Washing Machines
My whirlpool washer wont drain, and it makes a buzzing noise. still agitates.
    Scholar:
  • 106 Answers
In the front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down and then towards you. You will see the pump assembly right in the center with big black hoses.
You need a pair of pliers and a shop-vac if you have one, or towels and a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will start to leak out; use towels or shop-vac to mop up. Do this till all water is mopped. Remove the drain trap completely, you will find much junk; clean out completely and refit carefully, in reverse order.
You can rate me……
Posted on Mar 01, 2009
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Oct 24, 2012 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer will agitate only, no drain or spin
99% probability that your timer switch is done. The only remedy is replacement.
Aug 23, 2017 | Whirlpool Washing Machines
Wont spin and makes a buzzing noise in all cycles.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26912691
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
Since the washer will drain the problem is not in the Lid Switch (which tends to happen quite often with these washers)
The problem does however point to the Neutral Drain Assembly.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
The buzzing sound that you hear could be the small cams in the assembly trying to connect with the main spin gear.
Ours had basically the same problems.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
See the following for how to access the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Nov 25, 2009 | Kenmore Washing Machines
My Whirlpool washer, model number WTW5521SQ0 won't spin
This problem is frequent and is usually caused by the lid switch. It wont activate the spin for safety reasons, however it will drain. You should be able to hear the clicking of the switch while you open and close your lid. If you don't hear a clicking sound it is most likely faulty and will have to be replaced, part number for the lid switch is 8318084. If the switch is okay it will most likely be a transmission problem, and will have to be diagnosed by a technician. Check for any large oil leaks around the inside of the cabinet. If so this could be an early indication of a transmission problem Hope this helps
Thanks
Nov 03, 2009 | Whirlpool WTW5521S Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Noise during spin
You have something stuck in the drain pump.
Remove the pump and clear the debris.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal De
