Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
High pitched noise when spinning or slowing down(cat screaming)
It is 3 yrs old. when spinning, it gives a high ptched whine. When slowing down after spin cycle, it gives a loud whine like a cat until it stops.
  • 334 Answers
Sounds like you have bad bearings. I suggest you get it fixed before it creates further issues.
Posted on Jun 12, 2009
High pitched whine
check condition of drive belt and check tension of the belt as it may be slipping under load at revs.
Dec 20, 2013 | 2000 Oldsmobile Bravada
I have a magnavox 37mf331d/37 that has developed a high pitched whine.the longer the tv is on the louder the whine.the tv is 5-6 yrs old
It's likely a capacitor associated with the power supply having gone bad.
It's obviously beyond your expertise to repair it yourself.
Find a trustworthy repair shop and take it there.
Sep 05, 2012 | Televison & Video
When slowing down high pitch noise Hyundai i30 2011
your drivetrain is screaming already. Hope for the best.
Jul 20, 2012 | 2011 Hyundai i30 1.6
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Loud engine whine (like a jet noise) from 2002 subaru forester
Have you crawled under the vehicle and personally inspected your exhaust line from manifold to tail pipe? The roaring sound usually occur when there is a hole in the exhaust line. I had it happen to my forester before. A hole half the size of a dime made my subaru sound like my old 74 chevy pickup.
Dec 06, 2008 | 2002 Subaru Forester
Noisey dryer
Peace bumbabob,
Huuum t your service!
1-it may be the belt squealing or high pitched noises telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on! I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU
Sep 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Washing Machines Logo
441 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
