Because of wrong formattung procedure, so i lost all the U3 smart programs inmy Cruzer Flash Drive (micro 1 GB)
  • 33 Answers
Hi rodgafli,
first I would try to get my files back, so I would suggest you to try one of the products behind the following links: http://www.pc-inspector.de/file_recovery/welcome.htm http://www.recover4all.com/ http://www.partition-recovery.com/ If you don't want to try that (because no worthful data has been lost) you should reinstall the U3-Launchpad from Sandisk: http://www.sandisk.com/DriverDownload/driverList.asp After that you can reinstall the U3-software by using the U3-Launchpad. Greetings from Germany,
noris017
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 26, 2009
I can not format it
How do I uninstall U3 from my flash drive Most U3 smart drives come with an uninstall utility that converts the U3 smart drive into a regular USB flash drive. This utility can be accessed from the U3 Launchpad. Open the U3 Launchpad and click on Settings, then select U3 Launchpad Settings and click on the Uninstall tab. Some devices have a link to the Uninstall utility under Help and Support.
If you can not find the uninstall utility on your U3 smart drive you can download it from the following locations:
Remove U3
U3 removal tool for MAC
Jan 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lost instructions need to know how to download pictures to cruzer micro
USER MANUAL LINK
Copying to or from a USB device is the same as copying to or from any standard disk device.
1. Click on your desired file to select it.
NOTE: You can select multiple files by holding down the Ctrl while left click on the desired files. Or you can select all files by holding down Ctrl and press A.
2. On your keyboard, hold down the Ctrl key and press C.
3. Navigate to the desired folder destination.
4. Hold down the Ctrl key and press V.
U3 smart drive is a USB flash drive that allows you to install and run U3 smart applications from the U3 smart drive itself. When you use a drive in this manner, you can take your applications with you and run them on any Windows 2000 or XP computer.
Not only can you use the U3 smart drive for carrying your files but you can also carry your applications with your personalized settings with you as well. There is an application that is included on every U3 smart drive called the U3 Launchpad and it is your console for managing the applications that are installed on your U3 smart drive. The U3 Launchpad also provides utilities that let you customize your U3 smart drive your way.
More on U3:
Under the hood, a U3 smart drive is an advanced USB flash drive with special features that allow the U3 smart drive to take on multiple personalities depending on how it has been configured. The default configuration is composed of two drive letters or domains. One of the drive letters is a removable mass storage domain just like any other USB flash drive. The other drive letter or domain emulates a closed CD-R CD disc in a CD drive and contains the U3 system files that makeup the U3 Launchpad. When you connect the U3 smart drive to your PC, you will see two new drive letters after the Windows OS has fully set up the drive.
You will see the emulated CD-R drive which usually is indicated in file explorer by a U3 logo and another drive letter that is the mass storage domain. The mass storage drive letter will have a label with a name like "My U3 Drive" or some other manufacturer specific label. Newer versions of the U3 Launchpad lets you rename the drive letter label using the Status and Settings dialog. Older U3 Launchpads can be renamed by right clicking on its drive letter label in file explorer and selecting rename.
The drive letters assigned to the two drive domains by the Windows operating system can be any available letter but typically are between F: and Z:. The two letters may or may not be sequential and the mass storage drive letter may be before the CD-R drive letter. You do need to see both drive letters appear in order for the U3 Launchpad to run.
Dec 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Why usb device show extra cd rom
The Cruzer Micro contains a small operating system that allows it (and you the user) to run certains applications on any computer (Windows). It has the so-called U3Smart technology. The small U3 Smart OS appears as a CD-Rom drive. In addition to that the Cruzer has the normal flash-drive.
The interest of the U# Smart technology is that you use your own programs loaded on the key. Suppose you like to use Firefox, and the public/school/library computer you are using does not have Firefox, You plug your USB Micro Cruzer, and click the the LAUNCHPAD of the Cruzer (The cruzer CD-ROM icon). It installs an icon on the tray through which you access your applications. You scroll to find your Firefox and use it to surf the Web. All history, files downloaded, bookmarks, passwords to online banking, everything remains on your drive. When you remove it you remove all trace of what you have been doing.
You can also activate the security feature by setting a password. Even if it is lost, your data is safe.
Hope it helps.
Nov 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to download softwares to my sandisk u3 flashdrive
As you may know your U3 Smart drive has a small OS that allows you to run Your applications on another computer. This OS shows as a CD-ROM icon on which you click to execute the LaunchPad (TheOS) of the Cruzer. In addition to that you have the icon of a regular drive. (Usually the Drive letters are consecutive G and H for exemple.) When you safely remove one both are unmounted at the same time.
Once the LaunchPad has been executed, it installs an icon on the sys-tray. When clicked, that tray icon opens a pop Up window, giving a menu of the applications installed and which you can run on the host computer, but from your drive (U3 Smart Programs on the left) and on the right various menu options
  1. to explore the drive,
  2. configure the drive(settings),
  3. add programs (to download additional U3 programs),
  4. and enable security. etc.
So if you want to download additional U3 Programs to run from you drive you use the Add programs (option 3 in the list above)
However, if you just want to put regular files on the drive (pictures, text documents, etc.) you do as you woul for nay drive: You drag and drop the files, not on the CD-ROM icon, but on the other drive. You can also use the Explore option (option 1 in the list above) to open the second drive to see what is in it, add files, remove files etc.
Hope it helps
Nov 10, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk u3 micro 1 GB Cruzer
hi turn off your pc put the card into the usb then turn on your pc let the pc find the drives for it and load on if this dose not work try the same in another usb port ok
if it works you must format the 1 gig stick befor you use it
ok hope this helps
May 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Is the account that your tying to access the drive with an Administrator account? If not, Log in as Administrator and try to access the new drive. If you ARE using Administrator privileges on the vista machine, the problem lies in the U3 smart driver. Try downloading and installing the drivers for the XP SP2 os on scan disks website, If vista rejects the install package off of the scan disk website, let me know and i'll extract the drivers and build an install for them for you.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
