Question about Dell Inspiron B120 Notebook
Power cord shorts out
As soon as i plug the power cord into the back of my dell b120, the green light shuts off and it wont let me power up or charge. What could have gone wrong?
    Novelist:
  • 121 Answers
Three possible issues,
1. the cord is bad, to test this go to local PC shop and buy a universal power cord test it with this cord. If it works then your cord was bad and you have purchased the correct part. If it doesnt work return cord for a refund.
2. The connector inside the laptop that the power cord connects to is loose and has a short in it. If its loose take it to a PC Shop that knows how to solder and have them reconnect it securely.
3. The laptop has incurred internal damage possibly from a fall or ruff handling. If this is the case the Motherboard may need to be replaced. If this is the case consider purchasing a new laptop.
Hope this helps,
ArmyMason
Posted on Feb 26, 2009
  • Garrett Murray
    Garrett Murray Feb 26, 2009
    When you put the cable in the back of the computer does it wiggle? If it does it could mean the port has come free from the motherboard and is shorting out the system. You can take it to any repair place that knows how to solder parts back on motherboards. If its not wiggling I might believe its the power cord and to figure out if this is bad. take your computer over to a repair shop and see if they have a travel plug for your laptop. Use theirs to see if its your power cord.
    Good Luck,
    ArmyMason
Screen Flashing then Computer shuts down
The two things I've dealt with in cases such as yours is I have sometimes failed to have a 110v outlet really, actually working. The other problem was when I wouldn't be patient enough to plug in the computer and let it charge for a while BEFORE attempting to start it.. I'm not knowledgeable enough to know for sure, but, in your case, I might also suspect a bad battery... that was sucking up too much charging juice... to allow the computer to start up and run.
Jan 03, 2014 | Dell Studio 17 (1749) Laptop black -...
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Laptop wont charge
Remove the battery and try again. If it solved the problem the battery is shorted and must be replaced. Look at the plug in the back of the laptop for the power. Is it lose? if it is lose you have a short from it touching contactd together and it must be replaced. If neither of these work try using a loner power supply to see if it is that. The D600 has lots of Power problems on of witch is the Motherboard itself. Hope this helps you out.
Jun 06, 2010 | Dell Latitude D600 Notebook
My dell inspiron B120 will not turn on! What
hi there, there are many things that could be wrong here. First, make sure that the battery is plugged in with the power cord. If that doesn't work, it may be that the computer isn't reading that the power button is being pushed. If you know a little bit about computers and how to disassemble them and put them back together, take apart the top of the computer where the power button is, carefully disconnect the wires and look to see that the power button is not damaged. If it is, then you need to bring it to a computer repair shop for them to fix it. If not, then it is something to do with the connection between the power cord and battery not sending power to the system.
Feb 15, 2010 | Dell Inspiron B120 Notebook
I puug tn cord the green light goes off wont
check if the power ac adapter pin the goes to the side of the laptop is damage, if not then try connecting ac adapter with laptop to a diff power wall socket, if fails then replace the motherboard.
Oct 12, 2009 | Dell Inspiron 1501 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
Dell inspiron b120 laptop won't power up
i dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
Jun 23, 2009 | Dell Inspiron B120 Notebook
Dell Inspiron B120 Notebook Logo
171 people viewed this question
Alun Cox
