Question about Intel Computers & Internet
Microsoft.com opening problem & down win7
Microsoft.com is not opening properly & how to download win7 beta version & make it as a bootable cd
  • Frank
    Frank May 11, 2010
    find a way around the Microsoft web site, becaue they are the only one have Win7.
    the file is 6.5GB in ISO format. if you don't know what that means. then you should not be downloading the software.
    you going to have problem later on.
  • 490 Answers
SOURCE: Samsung SGH-X700
Anand ,in this case I will suggest u to delete the new version which is not working , then install version 4,1 again and check whether it's working or not. If everything goes fine, then try to reinstall version 4,2 again . may be ur handset is not supporting new version.Try this, surely it will help.
Posted on Oct 13, 2007
  • 87 Answers
SOURCE: Bios
actually u know what beta means? its acutally in testing mode they r still testing n finding the errors they made so when they find all erors n fix then they launch a full version of it so never download a softwares update of such sensitive stuff which r beta version always wait for the full version to arive
Posted on Nov 18, 2007
mraviteja
  • 51 Answers
SOURCE: to get a bootable 98 cd
Hello there.
I understand that you need windows 98 bootable CD.
If you want the entire windows 98 cd then go through this link..
http://thepiratebay.org/torrent/3611148/Windows_98SE_Bootable_ISO
You need torrent software to download this file .
Go to www.utorrent.com to download the utorrent software. After downloading install the software and double click on the previous downloaded file to open it in utorrent.
The below link would take you to a page where you can download only bootable s/w. Follow the instructions there.
http://www.bootdisks.us/windows-98/13/windows-98-bootable-cd-images.html
Thank you
Posted on Feb 17, 2009
  • 272 Answers
SOURCE: i had installed the windows 7 beta version. now videos not workin
windows 7 is still beta. It is till not a full operating system. Please let windows release the final version of windows 7.
Posted on Apr 04, 2009
Vanniar
  • 23 Answers
SOURCE: HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Posted on Nov 26, 2009
How do i reload the operating system?
I assume you have windows 7
If you are trying to recover a key of an already installed program on your computer there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry.
It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
Serial keys Location
Lift up your computer and look for a tag.
The tag will probably be located on the side of the computer, or on the bottom of the unit for a laptop.
The service tag is generally a large black and white tag and it will say "Service Tag Number."
Do not confuse this tag with the Windows tag, which may be located in the same area on the computer.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
http://www.windows7download.com/win7-windows-7/bzcdfrnu.html
The next version of Windows from Microsoft
http://www.windows7download.com/win7-windows-7/bzcdfrnu.html]Windows 7[/url]
Sep 09, 2013 | Toshiba NB505N508BL 10.1" Intel Atom...
Can not download
For that problem, you need to buy license product of Microsoft office 2007 full version right now There's No trail version for that. otherwise try this Microsoft office 2010 buy or trail version. to Download 30 days trail version. click this link http://office.microsoft.com/en-us/home-and-student/ Just Sign up and get email free keys for Microsoft office 2010.
Also try this openoffice3.4.0 freeware alternative for Microsoft office 2003, 2007 or 2010. all files Create for Microsoft office. also open office can read all files like Microsoft word, excel and powerpoint Files. to get this software installer click the following link http://www.filehippo.com/download_openoffice/ and then click openoffice.org 3.4.0 Beta at the right side green arrow down Icon. If finish downloading just double click software and then follow software installation step- by-step instructions. then register and try it. it's freeware.
I hope this information will be helpful.
Thanks using Fixya.
Aug 15, 2011 | Microsoft Office Professional 2007 Full...
How do I down load Windows 2007 to my computer
First of all its not windows 2007, its Windows 7. There are two options. Both need Win7 CD/DVD.
1. if you have currently vista installed, you can upgrade it by inserting the win7 dvd and selecting upgrade.
2. If you want a fresh installation, make sure the win7 DVD is bootable. That means when you insert the dvd in drive and turn you system on, the DVD should start win 7 setup.
Step 2 requires that your first boot device should be the DVD ROM. If you dont know how to check or set this, please revert with what computer do you have. Make/Model.
May 25, 2011 | Microsoft Computers & Internet
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
How to install windows 7?
Insert the cd boot from cd and follow the given instructions
Jul 26, 2010 | Acer Aspire One PC Notebook
I want to download msoffice2007 software for free
Can't do that, but your other options are:
Download and install Office 2010 beta from Microsoft: http://www.microsoft.com/office/2010/en/default.aspx
Open Office: http://www.openoffice.org/
Mar 09, 2010 | Microsoft Office Professional 2007 Full...
Windows 7 beta incompatible??
I have used acronis and win 7 with no issue.
Be aware though that win7 beta has a lot of versions so one may work fine and another maybe not.
As a Technet member I have the latest version and proper key etc.
Pirate versions may be subject to virus and other unwanted side effects.
Sep 11, 2009 | Acronis True Image Home 2009 Full Version...
To get a bootable 98 cd
Hello there.
Thank you
Feb 17, 2009 | Microsoft Windows 98 for PC
Computers & Internet Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
