here is a Ebay listing for laptop hinges for the 9400 series http://cgi.ebay.com/ACER-Aspire-9300-9400-9520-laptop-17-LCD-screen-hinges_W0QQitemZ120549686747QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c11523ddb
You will have to install them or find a person who is handy with disassembling laptops. 1. You will have to remove the cover of the LCD screen and then you will see the hinge support assembly.
Here is a site that may assist you with the taking apart and assembly http://www.insidemylaptop.com/fix-broken-dell-laptop-hinges-yourself/
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
the hinge may be under the power bar
a few screws, and are also connected to the brackets that run along the lcd,
the unit basically has to be taken apart completly
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
What does work is this- Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly. Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
These systems use a pretty generic hinge set-up. These can be dealt with in two ways, one involving a safer method for future adjustments. The hinges are two separate bars on each side of the monitor with friction cuffs that use the tension between their two pieces to hold the monitor stiff. Generally my experience with Acer models is that they ALL ship with pretty stiff hinges, which is a double-edged blade. Stock hinges that don't click when fresh have a tendency to need replacing after a couple years, where as my acer TM4K hinges are still strong today after 4. The best way to loosen these babies up is to just use it. About an average of 75 open/close cycles break in the hinge to where it stays nice & tight, but stops clicking or cracking. The other way, which is for those who are afraid the LCD housing will crack it's so tight, is to take the monitor off, but not apart, carefully using two pairs of needle-nose pliers, hold steady the monitor end with one set and with the other, flex the flat end of the now loose hinge back and forth as far as you can get it to move until you feel it is to the right strength.
It helps to mention that too little is better than too much, as I see a good amount of people burnt out with their Compaq Evo & Presario (ca.2001-2) hinges, falling to the ground soon as you let it go, only 6 months after their last replacement set.
