Question about Proscan 42LA30H 42 in. LCD Television
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Posted on May 20, 2009
    Problem Solver:
  • 4 Answers
I had the same problem at one time, however it was only on one channel, WGN to be exact, it only did it that one time and only on that channel, call your cable company maybe they can fix it through a filter or something.
Posted on Mar 25, 2009
    Problem Solver:
  • 12 Answers
I just got my proscan 26LB30Q yesterday and it is also buzzing. The picture is good though. I thought it was my electrical outlet, but its the Tv
Posted on Feb 26, 2009
My proscan plded3992a-c is flickering
Flickering can be adjusted. To some rare cases, the SMPS [Power] board might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 06, 2017 | Proscan Televison & Video
I have 39 inch proscan model plded3996a and the picture is flicker everything else work fine
Flicker to picture can be adjusted. To some sets, you have to adjust it at its main power supply regulator section [there will be flicker adjustment preset]; and to some others, you have to enter its service mode option to adjust this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase 'Flicker adjustment' or "Flicker" in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 31, 2015 | Proscan Televison & Video
My 55in.240 hz proscan tv flickers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. The output DC voltages comes outfrom it is not normal; and so the flicker occurs. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 04, 2014 | Proscan Televison & Video
Proscan 40" LED tv. Picture is flickering between fully bright and faded looking. Sound is fine. Could it be a bulb and is it worth fixing? TV is 14 months old.
Check the DC output voltages output from the main power regulator board [SMPS]. If it is abnormal, flickering can occur.
Aug 25, 2014 | Proscan Televison & Video
Television buzzing noise
Sounds like the audio output IC has damaged. Chekc and replace damaged component/s at its audio output stage circuit, or replace the audio output card. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 07, 2014 | Proscan 42LA45H 42 in. LCD TV
Akai pt50dl14x sms
Linda .....no its not the lamp thats causing the whirring/buzzing sound but the colour wheel, its housed in the light engine you will need to replace the whole light engine cos the inbuilt colour wheel is worn out this causes the buzz hence the lamp may not light up or u may have shut downs flickers on the pix or color issues
Jul 08, 2013 | Televison & Video
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
Tv buzzs when power is off.
Return the production without any further delay.
Oct 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LA30Q-screen will not turn on
This might help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Mar 30, 2008 | Proscan 19LA25Q 19 in. LCD Television
Problem with proscan 19LA25Q
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Thanks
Mar 16, 2008 | Proscan 19LA25Q 19 in. LCD Television
Proscan 42LA30H 42 in. LCD Television Logo
1,365 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
