Question about Whirlpool Duet GHW9150P Front Load Washer
Rumble/clacking while draining & spinning
Whirlpool duet washer has begun a rumbling clacking sound when it is to the end of the drain cycle and is beginning to spin out the load. It doesn't matter which cycle it is on.
  • jwatki2 Mar 05, 2009
    Wow! who'd of thought a pencil, a quarter and 15 BB's could cause such a racket! Thanks this was a real saver!!
  • Anonymous Mar 09, 2009
    I had the same problem until I read this post, thanks guys, we cleaned the filter, now it sounds like a new one, now we have to just find out where the water is coming from
  • 50 Answers
Check for debris in filter of pump assembly. The filter unscrews out of the machine. It is located behind the bottom panel. Remove the two or three screws holding the panel in place, gently ply down and you will see what looks like a handle. It will be hard to turn but unscrew it and check to see if there is any debris. Have towels near by as there will be quit a bit of water coming out as you remove it. It the unit still makes noise there is a good chance the pump motor is going.
Posted on Feb 26, 2009
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not drain or spin, keeps making a rumbling noise, what can I do?
Hello Randall;
My name is Peter. I am a retired field service appliance technician.
I have a Whirlpool Duet clothes washer. They are nice units. The information following is based on my model number GHW9150PW0.
You do not have a drain problem. I am more concerned with the rumbling noise.
1.) On both the front and back end of your drum you have a spring loaded counterweight. It is possible you have a broken spring.
Part #: 8181762 Cost: $24.00
Part #: 8181645 Cost: $17.00
Your should also check out your drive belt. At a high speed it may be slipping.
25395045-azn3vdefrt5enyqdbzatir1e-2-9.jpg Part #: 8181670 Cost: $25.00
The above will effect your independent motor control located inside the washer, located inside your unit.
Feb 01, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The drain pump of my whirlpool duet washer makes a ticking noise
Hi, Remove your strainer cover, located in the kick panel at the front, and use a mirror and flashlight to see up into the pump cavity. It sounds like there is enough debris in the strainer and pump to explain your problem. Remove any foreign material you find.
Regards, --W/D--
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet is making a clacking noise on the spin cycle.
Reach inside and see if there is any play to the inner/spin tub (up and down) . Tub may be seperating from mounting and spindle assembly.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet not functioning during spin cycle.
In front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down & then towars you. You will see the pump assembly right in the centre big black hoses.
You need a pair of pliers & a shop-vac if you have one, or towels & a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will begin to leak out; use towels or shop-vac to mop up. Do this till all the water is mopped. Remove the drain trap completely, you will find all sorts of junk, clean out completely & refit carefully, in reverse order.
Hope u appreciate this, u can rate me........
Feb 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De
