Question about Apple iPod touch
Computer shuts down when Ipod touch is connected
When I connet my Ipod touch to my computer - I get a message box stating that a digital camera has been connected and then my computer shuts down - when it starts back up I get an error message that a critical error occured. What is happening?
  • 2 more comments
  • jobers78 Mar 11, 2009
    i have the same problem. have tried unistalling itunes and reinstalling, but it doesnt change anything. HELP PLEASE
  • Anonymous Mar 22, 2009
    ok so how do you fix it?
  • Anonymous Apr 14, 2009
    when I connet my Ipod touch to my computer I get a message box stating that a digital camera has been connected and then my computer shuts down - when it starts back up I get an error message that a critical error occured.
  • chris1501 May 07, 2009
    I have exactly the same problem. Happened after I a downloading a latest itunes version. Any help welcome thanks
If u have taken any pictures with your itouch delete them and it would solve ur problem...
i had the same problem i deleted them and it worked perfectly fine
Posted on May 20, 2009
Shorted plug or shorted connection from ipod
Posted on Feb 26, 2009
I recently downloaded a photo from my ipod touch from face book and after that it started shutting my pc down once i connected it!now ive deleted it off my i touch it works fine,got no idea why but it worked phewwwww
Posted on Nov 01, 2009
Ipod touch model a1288 is disable forgot passcode and wont let me connect to itunes messages says enter passcode to connect
The most logical option would be...
- Connect your device to iTunes (The same computer it is set to sync with)
- Hold the power and home buttons
- After the device shuts down, release the power button
- Your device should then be in recovery mode, at which point you may release the home button upon seeing a message on iTunes that basically says it has detected an iPod in recovery mode.
Jan 14, 2013 | Apple iPod touch
I forget my passcode to get into my ipod touch
After a series of more failed attempts, your iPod displays the same "iPod is Disabled" message, but with an added "Connect to iTunes" message. At this point, your iPod shuts down completely and you cannot make any more attempts to enter the passcode. In order to restore the device at this stage, you need to connect it to a computer with iTunes installed. Ideally, connect it to a computer that you've used before for syncing your iPod.
Sep 04, 2012 | Apple MD057LL/A - Ipod Touch 8g 4th Gen...
Forget 4 digit code
Connect it to your computer it was regestered under and it should unlock it.
  • 1 Turn off the ipod Touch.
  • 2 Press and hold the Home button on the iPod Touch. This is located at the bottom of the iPod Touch. While still holding down the button, plug your iPod into your computer using the USB cable.
  • 3 Hold the Home button until you see the "Connect to iTunes" screen. Release the Home button when this screen appears. Click "OK" when you see the "Recovery Mode" alert.
  • 4 Click the iPod in the left column under "Devices."
  • 5 Click the "Summary" tab located at the top of the main viewing pane in iTunes.
  • 6 Click the "Restore" option. Click "Restore" from the dialog box that appears.
  • 7 Click "OK" in the dialog box that appears after the iPod Touch has been restored.
  • Feb 20, 2011 | Apple iPod touch
    I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
    connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
    this process is all on the computer.
    May 20, 2010 | Apple iPod touch
    Ipod touch not connecting to itunes
    Just click cancell on the wizard box. Itunes should load up then if you have already installed it on your computer.
    Sep 21, 2009 | Apple iPod touch
    I cant restore my ipod touch every time i restore my ipod touch it says waiting for ipod but the ipod not react... what should i do?... pls help..asap.
    shut ipod off.....get the usb wire and connect it to the pc..(while connecting to usb to ipod hold the home buttun down).....ituntes shoud pop up in few seconds on pc.....click ok (aftter u have read the grey box)....now click restore.......done.............
    Jul 12, 2009 | Apple iPod touch
    8GB iPod Touch Disabled
    you will have to restore your ipod to factory default settings in itunes.
    or you can jailbreak the ipod with software like quickpwn.
    Here is how to restore your ipod in itunes.
    You will need to put the itouch in DFU/Recovery mode to get it to connect.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
    Hold the Home Button down for 5 second (do not release it)
    Then Press and hold the Power Button for approx 10 secs (count them out)
    Your iPod will reboot.
    Release the power button and continue holding the Home button for an additional 27secs.
    You may see the screen go blank or not.
    Plug the USB end into the computer with itunes open.
    Your ipod will mount in recovery mode.
    Restore it and Your all set.
    if you need any further help let me know.
    Good Luck
    Jun 01, 2009 | Apple iPod touch
    Ipod touch wont get my mail
    well first u need to try restoring it on the computer and if is still wont connect then u may need to go on ur comp and go to the internet router settings and selet "add device or join new device"
    and that should work. :)
    Mar 01, 2009 | Apple iPod touch
    Disabled ipod touch
    my sons ipod has a message that states ipod is disabled....connect to itunes. but when we connect to itunes it still is disabled????
    can you help??
    please e-mail me at lewis.michelle@stl.sysco.com
    Feb 03, 2009 | Apple iPod touch
    I Touch won't connect to wireless router
    first off, make sure you have wifi enabled in your settings. if that doesnt work hold the home and sleep buttons untill your ipod shuts off and turn it back on. sometimes i do this when something is glitching on my ipod. check to make sure your your pass word is correct too.
    p.s. if you are really desperate, hold your home andsleep button untill your ipod shuts off, then continue to hold untill your ipod reboots. once it starts to turn on, just keep holding down the home button and NOT the sleep button anymore. a screen should pop telling you to connect to itunes. your computer will detect it in recovery mode and you can continue to restore on your computer. you can restore it that way or just do it by hitting the restore button in itunes :)
    Jul 07, 2008 | Apple iPod touch
    Apple iPod touch Logo
    930 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
