Question about Lexmark All-in-One Printer, Scanner & Copier w/ USB Cable
My printer isnt printing whats being sent to it??
I just bought a lexmark printer for my labtop. I set it up an it was working just fine. But for some reason when i go to print things it wont print them out. So i went into the control panal an looked under my printer an the information was sent to the printer. The usb cord is in the correct spot ( made that mistake last time), I have basic computer knowledge but no with outout devices so i gave up on trying to figure it out. Its happend before an my friend had it fixed in 2 min so i know its something simple i just cant pin point it...???
    Scholar:
  • 145 Answers
Go back and look at the printers (Start, Printers and Faxes) and be sure that your printer is listed and that it is set as the default printer.
If it is not, then right click and select "Set as Default"
If the above is already correct then right click on your printer and select properties. Click on the Ports tab and be sure the USB port is selected.
Posted on Mar 15, 2009
I have two computers on my network, an iMac and a PC running Windoew 7. I recently purchased the Lexmark Pro901 and installed it on the network. It(the Lexmark Pro901) seems to connect fine to the network...
It could be a software issue. Try to uninstall the existing Lexmark Pro901 driver from your desktop pc by going to Start menu -> Programs -> Lexmark -> Pro900 Series -> Uninstall Lexmark Pro900 Series. Reboot pc when prompted.
Now, check your Windows 7 if it's running on 32-bit or 64-bit by going to the Start menu -> right-click on Computer -> Properties. Take note of the System Type.
To reinstall, download the Lexmark Pro900 Series driver using the links below: - Lexmark Pro901 driver for Windows 7 32-bit - Lexmark Pro901 driver for Windows 7 64-bit
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Apr 10, 2008 | Lexmark T642 Laser Printer
Printer
Try this:
1. From Control Panel > Printers... delete all printers.
2. Unplug the usb cable.
3. Re-boot
4. Install software
5. Plug in usb cable.
Hope that works for ya...
Geno
Feb 27, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
Feb 24, 2008 | Lexmark X3470 All-In-One InkJet Printer
1200 series lexmar printer
My printer won't print neither black or color cartridges; it marks that it had 75% ink
remaining. How can You help me to find out what is the problem if is the printer or the
cartridges. Its been a year I bought the printer but it was in storage around 6 months.
I would appreciate if You can find the problem and the solution.
Thank You for your time.
Feb 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 All in One
I've never heard of that size paper the printer don't have that option the only possible sol. is to go to an A4 size ( European size) other than that try printing from Word and change the size of the Fonts.
Sep 17, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark All-in-One Printer, Scanner & Copier w/ USB Cable Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
