Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
My Whirlpool Dishwashe will not drain...before I mess around with
It how do I know if it is the motor or the hose? I put it on the rinse cycle and then hit "cancel" and I could only hear a small amount of water going through the drain.
    Scholar:
  • 102 Answers
I think that your air gap at the sink needs cleaning out. This is where your drain hose comes from your dishwasher to the sink and then to your disposer or your drain. Check this and you'll probably find your problem.
Posted on Apr 04, 2009
Whirlpool dishwasher du920pfgq3 will not drain
If you hear the drain motor running but water not draining then there appears to be a blockage in the drain sump or hose. Assuming your kitchen drain is clear you will have to check filters inside the dishwasher and worst the drain pump.
If you do not hear drain motor running then the drain motor needs to be checked.
Check part locations at this site
http://www.appliancepartspros.com/parts-for-whirlpool-du920pfgq3.html
Apr 22, 2014 | Dishwashers
Washer will not rinse
you can put the extraction pipe /drain hose to ground level and water will drain then should open vacume switch thw programer is at fault as the programe sticks
Aug 18, 2012 | Estate Washing Machines
Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Jul 25, 2012 | Whirlpool Dishwashers
My Whirlpool GSQ9364HQO washer will not drain, pump is ok.
Lid switch OR timer connection block loose, or motor capacitor OR sock in hose to pump. Service manual and more is HERE
Jun 12, 2012 | Whirlpool Washing Machines
My whirlpool front loading washing machine keeps stopping before the rinse cycle. I've cleaned the filter and the drain hose as well as all the inlet hoses. It stops and all the lights flash and it wont...
While it stops to rinse , does it drain off? if not there is block on the drain valve and so there is an error on the board because the water level sensor has to switch OFF and then ON to confirm that water has come in for rinsing.
So if the cycle is absent the possible fault can be the program controller. So you need to check the actions when the fault occurs, check for drain,.then after drain the inlet valve must open to allow water and then the water flow must cut off to start the motor.
If there is no action and output then the controller can be defective.
Apr 12, 2011 | Whirlpool Washing Machines
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Won't Drain
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LLC7244BZ0.cfm
Nov 08, 2008 | Washing Machines
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
121 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
