Question about Krups FBC1 1600 Watts Toaster Oven with Convection Cooking
Krups Toaster Oven elements stopped heating up
The heating elements of my Krups FBC1 Toaster Oven (only 3 years old @ $200.00) quit working. I was broiling garlic bread and sensed that the element was at an abnormally high temperature. I tried to stop the broiling process by hitting the STOP button, however it did not turn off. I had to unplug the unit. When I turned it on again to make some toast the following morning, the led light around the START/STOP button lit up, the timer still worked, however the two heating elements did not turn on. I checked the wall socket voltage and everything checked out okay. I'm suspicious it could either be a faulty fuse or thermostat. Can anyone help? Thanks for any advice you can give me. I would like to fix the appliance before trashing it. It was a gift from my family.
  • capn100 Feb 26, 2009
    I really appreciate your advice and conclusion. What is the alternative to an electronically controlled toaster oven as I'm looking to purchase a replacement? Aren't they all electronically controlled today?
    This site is awesome - I'll be passing it on to family. Thanks for your expertise.
  • warcraft demonhunter Mar 07, 2017
    If the elements are physically broken, you can order new ones and replace them yourself. I did it 6 years ago and use the oven every day. Here is the how to link:http://www.fixya.com/support/t9721249-ch...
    President:
  • 267 Answers
This is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Posted on Feb 26, 2009
  • BOB  BROWER
    BOB BROWER Feb 26, 2009
    no there not all electronic . as a rule if you stick with turn type knobs and stay with the low price units there are far less or no electronics in them
Where can i get a diagram of a Krups FBC412?
Maybe Krups can provide the diagram if you inquire.
Aug 20, 2016 | Krups FBC412 1600 Watts Toaster Oven with...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
Toaster not heating high enough
either the high voltage regulator is failing (you can test with voltmeter) Or the heating element is bad. You can test power to element.
Oct 24, 2009 | Krups FBC112 1600 Watts Toaster Oven with...
The heat element doesn't go on
FInd the break in the heater eliment and twish it bac together. It will then work again for a while.
Jun 29, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Krups FBC1 1600 Watts Toaster Oven with Convection Cooking Logo
1,380 people viewed this question
Top Krups Toaster Ovens Experts
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
