Question about Kenmore 63252 Microwave Oven
I have the 63252 model....When the microwave is turned on to cook, it runs, there is no heat.... does this microwave have fuses of any kind....
  • Kenmore Master
  • 5,568 Answers
Your oven may have separate fuses for the magnetron and the electronics so I suggest you pull the plug, remove the back and look for an accessible fuse holder. Allow the unit to stand unplugged for at least several hours before removing the back panel as there are components inside that can carry a nasty charge for hours.
Posted on Apr 24, 2009
Microwave turntable not turning, not heating up I have a fuse to try to replace, but don't know where it's located. Model # is 565. 69421
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';';
May 21, 2011 | Kenmore 63252 Microwave Oven
Our Kenmore microwave turns on, makes noise but has no heat. Any suggestions?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 30, 2010 | Kenmore 63252 Microwave Oven
Stopped working mid a 2 min set. no lights no clock display,
The most common cause of this type of failure during the cook cycle is the fuse melts causing a dead condition. To replace the fuse the cabinet has to be removed and the fuse replaced with the same type and amperage. Pay attention to the fuse holder to make sure it isn't burnt or corroded causing a poor connection which overheats the fuse.
Jun 21, 2010 | Kenmore 63252 Microwave Oven
63252 / 63259 1200 Watts Microwave Oven: Turns on but,wont heat up...
heatman101
hhgds
May 07, 2010 | Kenmore 63252 Microwave Oven
Microwave wont heat
look at the $2.00 door safety interlock switch(s) before you replace the very expensive (and hard and dangerous) magnetron.
Dec 23, 2009 | Kenmore 63252 Microwave Oven
Kenmore microwave model 721-63252301 - no heat turns on - but nothing is getting hot
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Jun 05, 2009 | Kenmore 63252 Microwave Oven
Microwave won't heat up while in use
It sounds like the unit is in demo mode, they usually have a small d on the screen, try holding the "kitchen timer" pad down for 5 seconds, it should then work, if that doesnt apply to your model look in the trouble shooting guide of your owners manual, it will explain how to deactivate "demo" mode there...Phil
May 18, 2009 | Kenmore 63252 Microwave Oven
The microwave won't boil water or cook the food we put in. its only saying power 100. what do we do?
I may need more information, however, I suggest that it could be either a dead magnatron or the high voltage fuse link to the magnatron. Check "Demo" mode, WARNING: if you try and replace the fuse or magnatron yourself, make sure of 2 things, 1/ unplug from the wall 2/ make sure the HV Capacitor is discharged before touching anything around the magnatron....also, I may need the model and brand for better diagnosis... Phil
Apr 06, 2009 | Kenmore 63252 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Kenmore 63252 Microwave Oven Logo
87 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
