Question about Sony KP-57HW40 57" Rear Projection Television
It wont stop shutting off!
The t.v. started to flash green for a couple days, and all of a sudden it flashed green and turned off, cant adjust anything because it wont stay on long enough. It shuts off every minute or so, also smell smoke haha. Did our t.v. go out?
  • Anonymous Feb 26, 2009
    My model is Sony KP-57WM500, 57" Rear Projection. It shuts off by itself! I can turn it back on, but then it repeats the cycle! Is it the power supply?
  • Jun2004 Feb 27, 2009
    I have Sony KP-57HW40 model. It shuts off by itself too. It can be turned on with the red and white strip screen, but shut itself off again.
    Scholar:
  • 41 Answers
You can try the suggestion on the site I posted below. This site addresses a specific problem that tends to be fairly common in some Sony sets. Only try this if your sure that the problem your having is the same problem described in the site. Look at the picture of the screen on the site and see if that looks like your screen. The set on the site is red but it could be Green or Blue also. If you set won't stay on, you may have to turn the appropriate knob down slightly in order to get the set to stay on. Although he mentions this will fix a convergence problem, the fix described has nothing to do with convergence. The symptoms you are describing do not sound like a convergence issue. I am however a little concerned about the smell. Another thing is, after the set shuts off the Led will blink a code. For example it may flash 8 times then pause and repeat. You can Google this to find out more info on the problem. Many things can go wrong with TV's, I recommend you do as much research as you can to narrow it down. Good luck, here is the site.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Mar 15, 2009
My 96 caprice classic vats security system has y car shut down. I had a after market ATS security chip also in my car and I removed it thinkingvthat was the problem. It wasnt.
OK. Turn on the key, let the light start flashing. Leave the key in the ON position. Leave it that way for 10 minutes. The VATS security is supposed to discourage a thief from stealing your car. It will flash for 10 minutes and then it will stop flashing. Now,,,,,, DO NOT turn off the key. DO NOT turn it off. Simply take ahold of the key and crank the car up. It will start and should never happen again, unless someone removes the instrument cluster, the battery, or other vital items like the ECM PCU. Good luck.
Dec 25, 2017 | 1996 Chevrolet Caprice Classic
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
PS3 wont start up has a flashing red light
That happend to me and i gave it a rest for a couple of days and it worked again
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
PS3 wont work
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Won't run - normal light flashes
When I had this problem, it turned out to be the heating element.
Jul 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Sony KP-57HW40 57" Rear Projection Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
