Question about Kenmore Refrigerators
Water leakage every few days a large puddle appears in front of my fridge, and there is also ice in a frozen sheet at the bottom of the freezer side. I stopped the ice maker for a few days to see if that was the problem but it still leaked...I think we had this problem in the past but I cant remember what was wrong.
  • Kenmore Master
  • 4,655 Answers
It is possible that your refrigerator is not defrosting properly. If it has a timer defrost try to turn it slowly clockwise until you hear a click and about one minute you should hear a crackling noise indicating the freezer is in defrost. If the timer does not turn and defrost about every 8 hours I suggest you change the defrost timer. Let me Know, Thanks, Sea Breeze
Posted on Feb 26, 2009
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Jan 27, 2009 | KitchenAid KSRD25FK Side by Side...
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Occasional leak at the bottom of the freezer side kenmore 25354703400 side by side
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 15, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Top Freezer Whirlpool
THERE IS A PROBLEM WITH THE DRAINAGE. iTS BLOCKED. YOU NEED TO DEFROST THE FRIDGE PROPERLY FOR A DAY TO REMOVE THE ICE THEN APPLY PRESSURE (BLOW) IN THE PIPE SITUATED ON TOP OF THE COMPRESSOR.THIS WILL CLEAR THE BLOCKAGE. RESTART YOUR FRIDGE.
Aug 14, 2007 | Whirlpool ET8WTMXK Top Freezer...
Refrigerators Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
