Greetings all,
I'm looking for recommendations for phono cartridges, for dubbing LP's to CD.
I originally started with the Stanton 500ALII. It's OK but not great. Someone
suggested I should change to the Stanton 680ELII. I looked at the specs on
this one, and the frequency response is similar to the 500ALII. The 500 is
rated from 20 Hz to 17 kHz with the 680 rated from 20 Hz to 18 kHz.
Is it worth changing to the 680 or should I go with something else? Cost is a
factor here, and I don't want to spend $100.00+ on a cartridge unless I have
to. Any suggestions?
To send an e-mail reply, write to
Thanks!
Robert
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Rating: 0%, 0 votes
S/PDIF digital output (especially since I bought a cart machine and had to
remove the turntable's analog output off of the mixer so I would have room ffor
the cart machine).
Robert
(Scott Dorsey) writes:
Rating: 0%, 0 votes
If the pivot is adjustable, I'd try the AT440, otherwise I'd consider
looking at one of the Ortofon moving magnets.
Yeesh... those internal preamps are usually pretty godawful. Stay away
from moving coil cartridges, even the high output ones on those things.
The Stanton 681 is still a good choice for 78s the top end detail
is not good and it has very poor separation, but it tracks very well
on heavy arms and because it's a wide ellipse, you can get away with
massive VTA errors. The problem with the AT440 is that because it's a
fineline, VTA adjustment becomes a lot more critical.
You may wish to consider a better arm and a good outboard phono preamp too.
Right now these are seriously limiting your options for cartridges.
--scott
Rating: 0%, 0 votes
1200MKII's. Mine is made by Denon. It's the DP-DJ151.
It doesn't require an ampliffier as it has a line level output level *although
you can use an amp on it in phono level output mode, but I don't).
It even has a S/PDIFF digital output on it, which is what I use to feed my HHB
CD Recorder.
Robert
Rating: 0%, 0 votes
pivot height? Can your preamp accept an MC input?
The Grado cartridges are very impressive and have a wonderfully lush low
end, but they won't work with a lot of light modern arms. Audio Technica
makes a fineline, the AT440, which tracks better than any elliptical, but
it really helps to have adjustable pivot height. Same with the Shure V15.
Some of the Ortofon moving coils are right around that price range too, but
again they need the right arm to work.
The arm and cartridge form a resonant system together and they need to be
chosen together.
--scott
Rating: 0%, 0 votes
other sources for well under $100. Far smoother & more musical than any
Stanton ever made.
Stephen Sank, Owner & Ribbon Mic Restorer
Talking Dog Transducer Company
5517 Carmelita Drive N.E.
Albuquerque, New Mexico [87111]
505-332-0336
Auth. Nakamichi & McIntosh servicer
Payments preferred through Paypal.com
Post a New problem for Denon DP-DJ151 Turntable
Email this problem
