Question about Casio Exilim EX-S600 Digital Camera
Won't charge my camera will not turn on. when it is in the dock, the light blinks red and green back and forth. when i press the photo button on the dock, the camera will show a slideshow of my pictures, but nothing happens after i take it off the dock. it will not charge and won't turn on. i have tried to take out the battery and put it back in. and i'm sure it's in the right way.
Replacing the NP20 battery fixed the problem. The camera works fine with a generic NP20 battery purchased on Amazon for less than $2.
I have struggled with this problem for about two years! - read this post on Fixya - bought new batteries - fixed!
Thank you!
Posted on Mar 22, 2009
  • 477 Answers
The batteries on those units go out all the time they will cost about 10.00 on ebay. get on there if that does not fix it then your only out 10.00. if you still have a issue with it I can help goto www.digitalcamrepair.com for more help.
Posted on Mar 05, 2009
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
Camera wont charge
Hi, if you are using the KLIC-5000 battery try to clean the metal contacts on the battery. Try also to remove the battery of your camera dock your camera on the docking station then turn on the camera, if the camera will not turn on it means the charging mechanism of the dock is defective. Now if the camera turns on it means the battery is defective that is why you can charged it.
Feb 11, 2010 | Kodak EasyShare Z760 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Docking station charges two of the three bars to green and then afterwards goes into blinking red bars and the third green bar never gets charged.
went to best buy and bought a new battery charger. i don't know what's wrong with the docking station but at least i'm back in business insofar as being able to continue using the camera.
Sep 20, 2009 | Kodak EasyShare Z760 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
Red flashing light, constantly.
this is the fix.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Jun 02, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Mar 23, 2008 | Kodak EasyShare Z760 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
160 people viewed this question
Top Casio Cameras Experts
Fred Block
Fred Block
Are you a Casio Camera Expert? Answer questions, earn points and help others
