Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Cl is showing on display and machine wont work
As above LE is showing on the display and the machine wont work
  • fixer444 May 11, 2010
    Click on 'TROMM 4.0 cu ft........' above in blue, you will several solutions...........
    Scholar:
  • 106 Answers
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Posted on Feb 27, 2009
Error le on lg direct drive washer what can be done without a repairman
often that is a hall sensor-motor speed/position sensor. common issue. easy replacement. part under $20. check out youtube or repairclinic.com or appliancepartspros.com for how to video. part readily available at above sites or on eBay. just plug in your model number and the parts list will come up. takes about 30 mins tops
Oct 22, 2016 | LG Washing Machines
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
My display is alternating between CL and and won't take messages. What should I do.
CL means that the clock is not set and when that is the case, the answering machine wont work.
Oct 03, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
Cl code on the display screen
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work.
May 18, 2012 | LG Washing Machines
POWER BUTTON DOES NOT WORK AND DISPLAY SHOWS "CL"
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 16, 2011 | LG Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
Machine shows Cl on dispay
cl is over loaded push stop clear to clear then try again with a lighter load
Jan 30, 2008 | Westinghouse WWS833ES Super Capacity Top...
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Washing Machines Logo
121 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
