Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
Kohler single lever kitchen faucet,no hot water
Just installed a kohler single lever faucet w/ pull out sprayer. when I turn it to hot only a drizzle of warm water comes out.old faucet worked did not have this problem, is there some sort of adjustment I don't see?
  • brokefaucet Feb 26, 2009
    I am having the same problem
  • Anonymous Mar 16, 2014
    very difficult pulling the faucet forward for on and pushing it in for off, works very hard, but turning it to control water temp is fine
  • 547 Answers
No its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
Kohler sprayer with forte single handle, will not spray well. When sprayer is on the flow to faucet cuts off but there is only a small amount of water coming out the sprayer.
Check to be sure the hose isn't kinked somewhere below the faucet. If there aren't any kinks there is likely debris stuck behind the nozle screen, remove it and clean it- or your handle mechanism is broken. Replacement handles and hoses are fairly inexpensive if you need one they're easy to find at most big hardware stores or on Amazon
Sep 05, 2013 | Kohler Kitchen Faucets. Forte 1-Handle...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Irregular water pressure from kitchen faucet, single handle pull out sprayer. What could be the cause and how do I fix it?
Do you have similar problems anywhere in your house,dose this occur when another water source is turned on,if not then a small pressure tank can be installed to regulate and stabilize the water flow at faucet,if you need further assistance re-post giving more detail about exactly what is accruing.
Jun 14, 2011 | Kohler Plumbing
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
I used different length supply lines because th hot water line was a little short. Would this cause the side sprayer to move when the main faucet is turned on or the faucet head to drip?
No the length doesn't matter. When you turn the faucet on, you also fill the hose to the sprayer, and it may expand slightly, causing the sprayer to move a little. Is the drip from the end of the spout at the aearator? or is it around the faucet lever. If it is the lever, you should be able to tighten it slightly. If it's the end, make sure your aearator is clean.
Jul 18, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
My Kohler single lever pull-out faucet stopped working. Raising up does not start water flow. Turning left sometimes starts some hot water, but raisinglever up and down does not start or stop water flow as...
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Apr 28, 2010 | Kohler Model 10433: Fort® Single-control...
I have a Kohler Forte Single handle faucet, and I'm seeing leaking down below the sink in the cabinet. I tried reconnecting the Kohler piece to where the water comes out, but now it's even worse. It looks...
Turn off your water supply to the sink the disconnect the supply lines to the faucet. Reconnect supply lines making sure to use plumbers pipe joint compound of teflon tape. I've found teflon tape to be better. When installing the supply lines make sure that the threads aren't crossed and the retaining nut is snug.
Mar 12, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
1,688 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
