Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Posted on Apr 30, 2009
How to replace fuel lines on Poulan P3314
I am asuming you are already into the saw and looking at the carb and tank. There are two fuel lines, one gets gas to the carb, the other returns gas to the tank. The 'in' fuel line has to be long enough so you can pull it out the gas fill hole to attach the filter and to rest on the bottom of the tank. (The weight of the filter will keep it on the bottom.) The 'out' line only has to be long enough to go into the tank but not vibrate out. Both should be fairly snug in their holes so gas won't leak out around them. Either line can go through either hole in the tank however, one hole is usually easier for each line to run in without kinking. If you don't know which nipple is which on the carb, put one end of a line on one nipple and the other end in some gas and pump the primer. If it sucks gas up, it's the 'in' nipple, if not it's the 'out' nipple. If you got the 'out' nipple, be sure to check the other to make sure the primer is working properly.
Feb 22, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Fuel line is broken 2 inches short from filter in tank. How do u replace line? Do you need rubber grommets etc.
if you go to home depot you can buy a fuel line kit for a few bucks that comes with all of what you need
Mar 01, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Started reving very fast wont idle ;was the correct fuel mix was cutting on side ie not down
Check your all of fuel lines for cracks / air leaks especially near any fittings. Also check the primer bulb (if installed) for any pin holes. The symptom you describe is either caused by fuel starvation or the introduction of air into the fuel system. Also check inside the gas tank looking at the fuel pick up tube END / strainer for debris. Make sure that the gas cap remains vented. If some one has placed plastic over the fuel tank fill hole and then the gas cap it will perform as you stated. This model also has a mini fuel filter that can be clogged causing fuel starvation.
See this link:
http://www.ereplacementparts.com/poulan-p3314-type-gas-chainsaw-parts-c-16962_17147_17782.html
In DETAIL A
There is a fuel line item A7 and a tank purge device item A6 that is often where the air leak presents itself.
in DETAIL B
The primer bulb item B14 and the purge line B13 are also a major source of air introduction.
Once you get the feul system sealed again by repair of the fuel lines or replacement of the primer bulb you should be back in the wood cutting business again WITHOUT making carb aadjustments.
Thanks for choosing FixYa,
Kelly
Jan 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 2050 14 inch chainsaw . Problem is ,it wont start. Has been good saw. Seldom used.while idling it quit running.so I went to refuel and noticed, it was not out of fuel.I pulled fuel filter to clean...
Same same for me as well ..need to rebuild a small engine
sorta fun on a small engine you can do it at kitchen table with your wife playinf solitare OR get a tV table and rebuild it on the porch
poor start scalled port good catch on your part to notice scorch
Jun 16, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Primer bulb will not fill
This answer assumes you've put gas mix in the fuel tank.
Unless the saw is new (and possibly even if it is) there are only three things which can cause this:
1) The primer bulb is split or has a small hole in it (they rot and split often, but are not much trouble to replace)
2) The line between the bulb mount and the fuel tank is split or has fallen/been pulled off (this frequently occurs as well)
3) The fuel tank filter has trash on it and is preventing the prime. (this is harder to check and/or fix, but not impossible- and all of these are cheap!)
Dec 26, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Oct 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 14" chainsaw, fuel coming out of fuel cap vent
The fuel cap has a rubber check valve in the top. This check valve allows air to enter the tank so fuel can flow. Much like the vent on your gas can. Sounds like the check valve in the cap is stiffening and not flexing. Best bet is to buy a new cap. Most caps like that sell for less than $3.
Feb 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do you get new fuel line into the gas tank of poulan chain saw?
FIrst off be sure you have the correct size line. Poulan uses several sizes of fuel line. If you got the wrong one, you won't get it to go in. The best way is to cut the tip of the fuel line at an angle. If you warm the fuel line before inserting it, it will go in easier. Once you get it forced in a little ways, you can reach in with a pair of needle nose pliers and pull on the fuel line while pushing it in from the outside. If you bought the line from a Poulan dealer, then instructions would be included along with the end being precut at a long angle to assist with installation.
Feb 22, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
1,083 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
