Question about Vector VEC056 MAXX Power Inverter
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
I attempted to run a small 750 watt heater for 15 minutes and the inverter overheats. The fan has not worked since about 6 months after I purchased it. I have only used it to run a small refidgerator that is on constantly but only requires power less than half the time. I also run a 1000 watt microwave for 10 minutes at a time and the inverter doesn't overheat.
    Guru:
  • 290 Answers
Your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
I need to replace the fan. Where do I find one.
you may find that walmart has those for under 20.00 and a fan is 25.00 and you take a huge risk of electric shock and damage to your car or equipment trying to do a stupid pos inverter, get my drift?
walmart.com
Dec 02, 2010 | Vector VEC 024 400-Watt Power Inverter...
I have a vector VEC051C 3000 Watt inverter, the vent fans run continously without load, can it be modified to cool only when, the temperature increases..
If it has a 12 volt fan, you can replace it with one designed for computers that has a built-in thermistor. These fans will automatically increase or decrease their RPM depending on the ambient temperature. I have seen them in 70,80,120mm sizes. As long as the inverter is on, you do not want the fan to ever be completely off because even without load some heat is generated and can build up inside if no ventilation is present. Although the fan will never completely turn off, this might be the easiest solution if your goal is to make the inverter quieter (and use less energy) when not in use.
Oct 20, 2010 | Vector 3000 Watt Power Inverter
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
Fan doesn't run on my power inverter
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
Aug 31, 2017 | Black & Decker Electronics - Others
When I charge my jump starter, do I have it on or off for it to charge?
off, never leave it on, danger of short if the clamps touch metal, turn it on only when you are using it to help start a car
Jan 09, 2010 | Vector VEC 024 400-Watt Power Inverter...
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Does item have a fuse? Burned out
i have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Aug 16, 2008 | Vector VEC 024 400-Watt Power Inverter...
Vector VEC056 MAXX Power Inverter Logo
614 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
