ASUS P4B533-VM Motherboard Logo
Suneel Pandit Posted on Mar 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IBALL SIS AGP CONTROLLER - ASUS P4B533-VM Motherboard
Hans Pedersen
Level 3:
  • ASUS Master 3,606 Answers
  • Posted on Mar 19, 2013
Hans Pedersen
ASUS Master
Level 3:
Answers
3606
Questions
0
Helped
2232126
Points
8683
Hello try the SIS homepage here:
http://w3.sis.com/download/
Or here:
http://w3.sis.com/support/support_faqs_26.htm
You have to select the windows system you are using, and the graphic card model, to find the driver.
Good luck
1helpful
I have a ECS 761GX-M754 1.0 motherboard. I just replaced my hard drive and now I don't have any sound. My device manager said my video controller (VGA Compatible) isn't installed. Do I need to update the...
yes it sounds like you will have to re-install your drivers, and chances are, if the video and sound aren't installed, none of them are...
i'll link to each driver you need to download in the order you should install them.
1. SiS AGP VxD Driver - http://download.ecsusa.com/dlfileecs/driver/mb/vga/sis/Agp_121.zip
2. SiS 900 LAN driver - http://download.ecsusa.com/dlfileecs/driver/mb/lan/sis/sis900_116b.zip
3. SiS UniVGA3 driver - http://download.ecsusa.com/dlfileecs/driver/mb/vga/sis/sis660.zip
4. Analog Devices AC'97 Audio Driver - http://download.ecsusa.com/dlfileecs/driver/mb/sound/adi/AD1888-123.zip
if you're not sure how to do the zip file thing, easiest way is to save all your downloads to your desktop, then once they are downloaded, right-click on each one and say "extract all", then a folder of the same name will appear on your desktop. go into there and you'll find your setup files!
hope this helps!
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Ati2dvag infinite loop
mmm... try this steps.. maybe it could help.
Right click-mouse over My Computer
Properties
Hardware(Tab)
Device Manager(button)
Click [+] next to System devices
right-mouse on CPU to AGP Controller (or whatever your controller is called, mine was SiS AGP)
Update Driver(button)
Select Install from a list or specific location (Advanced)
Next(button)
Select Don't search. I will choose the driver to install.
Next(button)
Select PCI standard PCI-to-PCI bridge
Next(button)
Finish(button)
Reboot.
1helpful
2answers
I need driver help, yes i am a idiot
No your not.Go to microsoft web site or use the built in Windows Update on your computer.If you haven't downloaded the update tool it will ask you to install it.After it installs the update tool, run it.Pick the updates you need lnstall them some will require you to restart.Later check the automatic update feature to check for updates.Other updates will be from the manufacturer or your PC,check for their updates.Software from their sites.This is not hard.If I were you I would buy a general book on XP you can learn easy steps to keep your PC up to date and won't have to ask anyone (except FixYa.com) good luck
1helpful
SIS 315, 256-BIT AGP 4X VGA CARD VS GREEN ATI 7000 SERIES CARD
The ATI 7000 graphics cards are much better than the SIS 315 ones.
1helpful
DRIVER PROBLEMS
you have to install the chipset driver using your driver cd...
is this cleared your problem?
2helpful
11answers
Drivers
If it is a laptop or a brand PC, just post a new request on Fixya with computer's make and model, for explample Dell optiplex 120, we will find the drivers for you.
Ifcomputer is assembled you will need to access the motherboard, and the audio card and posthere the code number printed on the motherboard, on on a sticker on top of the motherboard, and post also numbers you find on all device cards (PCI, AGP etc.).
Here is how board identification numbers look like
See also:
Motherboard Identification
and
How to Find Out Your Motherboard Manufacturer and Model
Geforce 512 agp ddr2
Hi sledgehammur, you're asking if the SiS 651 controller will allow you to run both the on-board integrated AGP4x & the Geforce AGP DDR2 card to function as one. I don't think your SiS controller will allow it to. You'll have to enter bios & change the on-board graphics not to load frist. (Keep in mind the on-board is also an AGP), but the memory is not the same & neither is your system memory which the on-board AGP use's.
You're manual for the board would give you more insite on that issue. My thoughts are you will need to change bios to run from AGP slot on your board & not use the integrated AGP. The good part is your AGP slot will not use you're system memory to run. You're Geforce's memory is faster.
Here is a link to the SiS 651. http://www.sis.com/products/sis651.htm
Enjoy!
If I can be of more service, just ask.
Mike
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
