My wash was interrupted by the main fuse tripping now the machine wont start ,the start/pause button keeps flashing and nothing else happens
Switch off the machine for a while. Check for moisture in the panel, check for any capacitor leak in the mains circuit. If you have a multimeter check the voltage to the controller section.
Also check the door switch, the inlet flow valve filter and the connectors.
If all these seems fine there are errors in the controller board section.
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
