Question about Acer Aspire 3680 Laptop
Purchased restore disks for a Acer aspire 3680 and replaced hard drive. It loads ram disk and begins to restore then says please wait....... How many days should I wait??? Also tried to install Windows XP but it stops when it says starting windows. The computer did have Vista on it. Do I have to do something to the bios or is the computer toast?
  • 1 more comment
  • garyk1949 Feb 26, 2009
    It has been set to CD first.
    Something is stopping installation of any operating system. I have tried the the restore disks, windows XP, and Free Dos. Can run free Dos from CD but cannot install to hard drive. It seems that I cannot write the MBR. Spinrite and manufacturers diagnostics indicate the the old and new HDs are working fine, have also reset the Cmos.
  • julianka2 Feb 27, 2009
    How can I get the restore disk and windows vista disk for my computer? My computer was shipped without those disks. My computer is not operating. I attempted to restore it and now I cannot access anything because windows in not coming up.
    Problem Solver:
  • 17 Answers
Why would the computer be toast? Unless it's been physically damaged, then installing an OS should make it all better.
Try Ultimate Boot;,ultimate-boot-cd-411.aspx
Posted on Feb 26, 2009
  • Seabee Tim Feb 27, 2009
    @ julianka2, contact your computer's manufacturer, you may have to pay for your discs plus shipping, probably around $20 or so. Or you could always be naughty and download a pirate, but that would be wrong because it costs a lot of money to fuel a jet and heat a mansion, Bill Gates has bills to pay... If you have no conscience, look at
    Gary, it's starting to read like there's a problem with your disc drive. I'm at a loss.
  • Acer Master
  • 1,800 Answers
Check boot order in bios set the cd rom in priority one!!
  • Jalal Sordo
    Jalal Sordo Feb 27, 2009
    try use a new or external HDD
Cara mematikan mode smart pada aspire3680
If this is about hard disk drive SMART (Self Monitoring) warning. Acer Aspire 3680 BIOS does not have an option to turn off this warning. Basically, your hard drive is dying and you need to replace it with a good working hard disk drive because sooner or later your hard disk drive will stop working. You can clone your hard disk drive using an hdd cloning utility such a Farstone Clone Drive.
Mar 05, 2014 | Acer Computers & Internet
I can not fix recovery factory my pc
If you laptop was not supplied with a Windows CD then most likely the hard disk on your laptop has a recovery partition on the hard drive and you can restore your laptop back to the condition when you first purchased the laptop using this recovery partition.
Acer can also supply a recovery CD for your model Acer if you request one. This is needed when the hard disk has failed.
Read your laptop documentation for the instruction on the restore procedure. You also get this information from Acer's WEB site.
Apr 25, 2011 | Acer Aspire AM1610-U1201A PC Desktop
I have the aspire 3680 but it hasa mk8034gsx-si hard disk that has gone bad what do i do?
You may need to re-place the hard disk if it gone bad, the picture shows it procedure of replacement.
The hard drive can be easily accessed from the bottom of the laptop. Simply remove the hard drive door, remove four screws securing the hard drive caddy, disconnect the hard drive from the connector on the motherboard and remove it from the laptop.
After that remove all screws securing the hard drive to the caddy and transfer the caddy to the new hard drive.
Hope this helps, if so rate the solution
Jan 20, 2011 | Acer Aspire 3680 Laptop
The hard drive crashed so I bought another (larger) HD for my Acer Aspire 3680. when I try to install OS Win 7, the laptop does not recognize the hard drive, new or old. The install program keeps asking...
The best option is to install WinXP on the new drive, partition the drive
C:, D:, E: etc
and use C for WinXP
Once you are done with WinXP install Win7 in D
let me know
Nov 29, 2010 | Acer Aspire 3680 Laptop
MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
This one can do to remove the Hard Disk and try to enable it without hard disk.
if the problem is both are still remove the memory and clean it.good luck
Aug 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Unable to recover system
see if your system restore is in my computer c:\ drive
should be there it will probably say acer on the folder
restart while in restart press F7 then when options appear select boot with cd or cd/dvd
then enter this will start the system with the cd
if it does'nt start the win setup then restart might need to try a couple times
if setup still does'nt start then make sure the cd is the right recovery disk
Jan 27, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 will not detect hard disk. In command prompt where should be, there is
Hi there,from the sounds of it this lovely little excercise is due to the hard drive failure,either that or no OS - XP disk is dead or damaged.
If you have the original restore disks from the 3680.
You could try reinstall and test from there,If your contents were important then try to remove hdd take to another computer and see if the drive recognises on the other machine,
If it allows access ,copy all your settings and documents straight away because it could die shortly,hopefully not tho....
Once the back up of your docs and settings and hdd back in your computer then use the restore disk to revive your machine,
This process wipes the C Drive and does a complete reinstall of all the required softwares and in the correct order too...
It should take 15-20 min to load onto the machine and about 40 minutes to reinstall all the RESTORE to Factory Defaults Settings.
Just let it do this process from start to finish and it should eject disk when done and reboot by itself.
when it starts up again it will be back to the windows activation screen and the ready to start loading up if your have the original restore disc,
Once your happy with it and its working,
How do I create a restore point?
This will help you return to the point when everything was working,
If you should'nt encounter any more problems,
There may be a Hidden Partion on your hard drive that may allow you to restore from that.Then all thats needed doing is the bios settings will need to be changed to select the XP CD on bootup or the hidden partion on bootup then select save and reboot,It should be straight forward from there.
Just about finished,
Dont for get to do your windows updates for SP2 and then turn off the update functions.
And BACK UP the new install to DVD blank so you can restore
any other time you have issues
I hope this helps but that should cover itn for you,
If you need more help please let me know.
Thanks Misterdj
Jan 14, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 too slow
Sure but if it has acually been slowing down you must also find the problem. Have you disk cleaned up and defragged your hard drive lately. Cleaned out all the junk from your internet exploier?  Have you gotten rid of everrything that you don't need or want. Slowest thing in a computer is the Hard drive seek/read time.
  According to you manual (Link below) You can have up to 4GB total memory. Two strips of 2GB each soDIMMs
Jan 04, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Complete Restore Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
Apr 13, 2008 | Acer Aspire 3690-2196 Notebook
Computer stopped working - shows message "Failure Fixed Disk"
Do you get the failure when you are booting up your computer? if not when exactly do you get that problems you are having?
Jan 03, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
201 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
