Question about HP Pavilion a1610n (882780664463) PC Desktop
Monitor only wakes up when fans get quiet. replace video card, power suppply, and tried differeint monitor, key board and mouse. turn computer off and unplug for a few days it will come on, but freezes very quickly, usually before it boots up all the way. Only thing I can think of is a bad motherboard. can you help
  • 916 Answers
Check your heat sink and fan assembly. It sounds like you have a bad heat sink and your cpu is getting to hot.
Posted on Feb 26, 2009
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
Monitor will not wake up with keyboard or mouse after going to sleep from inactivity
turn off the computer's power management, there is an issue with the video card/OS and your power management. Set the power management scheme for the monitor to always on, or disable power management in the BIOS of the computer.
Mar 08, 2011 | HP w1907 LCD Monitor
Green p0wer light flashing on screen but no display
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly
vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your
Nov 27, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
When i trun on my computer the monitor will not work. it says Check Signal Cable
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
If another monitor works on your computer it is safe to assume that your monitor is bad.
Nov 14, 2010 | HP Pavilion Slimline s3500f Desktop...
To give background I have DG45ID mother board, and a ATI 5570 video card. My computer works with no problems until it goes to sleep for more than I few minutes. When I try to wake it up after it has...
Try updating all the drivers. Mainly the chipset and the video card drivers. If you have a wireless card, update it too.
Also make sure that the onboard video card is disabled in the setup-
Nov 09, 2010 | Intel DG45ID Motherboard
My monitors sleepy
Go to the control panel on the computer and look for power options. On the first page there is power schemes, make sure the scheme is on "Home/Office Desk", below that make sure everything is set to "Never". If you don't want the computer "Hibernating", Go to the "Hibernate" tab and uncheck the box. Hit apply and OK. No more sleepy monitor.
Sep 11, 2009 | LG L1919S LCD Monitor
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
Motherboard detects nothing
anniegms, I had the same problem with a new Asus board running a Dual Core Duo Quad processor. The boards BIOS was not updated to handle the Dual Core Duo yet. I had to switch processors to a P4. Use a different PC to make a BIOS update disk. Update the BIOS and switch processors back. But I had all the same symptoms of yours. However I did/do have a PCI-E XFX Fatality (Nvida) based graphics card. I would check or swap processors, it sounds like the board is waking up but not the processor. Just my thoughts.... PCdok
Oct 21, 2007 | ASUS P5GD1-VM Motherboard
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
HP Pavilion a1610n (882780664463) PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
