Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My TV shuts off after 10 min.
Tv shut off and blinks a red light after 10 min. of use repair man said something about a switch an door . His company called back and said it needed a t1 and t2 board do i really need that or just a switch an door
Just clean out the air input on the side of the unit and clean out the fan..its hitting the temp limit for the lamp.
Posted on Feb 27, 2009
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
First blinking green light tv would turn on for a few minutes then turn off, pushed reset button and unpluged but problem would continue now theres no sound no picture and just a steady red light. Please...
The red light is indicating the set has shut down for a specific reason. You can dtermine the reason by going to the sets front panel and pressing the menu button and the device/input button both in together and hold for 6 seconds. The light will switch and begin to blink a series of blinks( First number) and pause briefly then blink another number of blinks (second number) then it will repeat that same two digit blink code. Let me know the code and I will let you know what happened to shut the set down. Respond to this same post for assistance.
Aug 12, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Samsung TXF2899 28" TV that is not turning on. When I press the power button on, I hear the power-on sound, it's red power indicator light blinks 10 times as if running a test but then...
It's running through a self diagnosis when the light blinks. The 10 blinks just happens to be how long it take to find a problem. Would have to be plugged into Variac and started at about 90 volts in order to keep it from shutting down. The life of a Television is averaged at 10 years, however most last longer and it could be something very simple to fix or something major. Thing is get an estimate from a reputable co before having it fixed and consider the cost to repair, age of the TV vs the price and warranty of a new one.
dhgill1949
May 22, 2011 | Samsung TXF2899 28" TV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
