Question about Western Digital imicro IM35ST320SI 3.5 IDE HDD External Enclosure and WD250G SATA Hard Drive
How do I install the disk supplied with my hard drive into the unit as it explains (poorly, I might add)?
  • 916 Answers
If this is the only hard drive in the machine load the disk while you are loading up the machine. You may have to change your boot order in the BIOS to having cdrom be the first boor device. To get into the BIOS you usually press either f2 or delete while the computer is starting. This should load it's drivers and then you can insert a windows or other operating system disk to install that. If you would like you can also install windows and then press f2 when it asks if you would like to install third party drivers.
If you are installing this drive as a second drive go to control panel and then add hardware. Make sure the disk is in the drive and then let the add hardware applet search for the drive and install the drivers and you should be good to go.
Posted on Feb 26, 2009
Blue then red light. Why is it not seen by the computer?
There are so many things to be considered why the hard disk drive are not detected by the computer. Poor data cable, defective power supply and worst the hard disk drive. Let's say your hard disk drive having a problem. Here is the best link for you
The World of Full and Free download and install this software it will repair most common hard disk problem. This video tutorial will help you to scan and repair your hard disk. HDD Regenerator 2011 have a nice day
Apr 14, 2015 | Computers & Internet
When drive turned on blue light appears then red light comes on & computer cant see hard drive
There are so many things to be considered why the hard disk drive are not detected by the computer. Poor data cable, defective power supply and worst the hard disk drive. Let's say your hard disk drive having a problem. Here is the best link for you The World of Full and Free download and install this software it will repair most common hard disk problem. This video tutorial will help you to scan and repair your hard disk. HDD Regenerator 2011
Apr 14, 2015 | LaCie Computers & Internet
Do I need a seperate dc supply for my Ultra traveldrive usb 2 Why won't it install on my lap top.
> do I need a separate power-supply?
It depends. If the disk-drive inside the enclosure is a 2.5-inch "laptop" disk-drive, then it will draw the necessary electrical power through the USB cable. However, if the disk-drive is a 3.5-inch "desktop" disk-drive, it does require an external power supply.
Will it install on some other computer?
Dec 18, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Trying to install as slave. check disc checks it then computer stops???
since you have been connecting another hard drive and plugging the leads in/out
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection
i would also suggest you buy another PSU power supply unit preferably a heavy duty one with plenty of wattage when you add more devices ram,hard drives,cd/dvd recorders it drains more power from the power supply unit placing more strain on your computers PSU
and are not faulty or just replace them there probably old and faulty
Nov 30, 2010 | Maxtor DiamondMax 16 80 GB Hard Drive
How to install amd 64 mother board cd
install the flat cables coming from the hard disk drive, optical units and floppy disk drive. If you didn't install these devices to the case yet now it is a good time to do so. The cable from the hard disk drive must be installed on the IDE1 (primary) port and the cable from the optical unit must be installed on the IDE2 (secondary) port. The floppy cable should be installed on the floppy port. To install the cable, just pay attention on the red wire, it should be installed facing the "pin 1" marking on the motherboard. This marking is usually a number "1" or "2" painted on one of the sides of the connector (the opposite side should be marked "40" or "39", or "33" or "34" in the case of the floppy port).
imageview.php?image=631
Figure 19: Cables from the hard disk drive, optical unit and floppy disk drive correctly installed.
The next step is connecting the power supply. The power supply has one 20-pin connector and your motherboard can have an extra 4-pin connector called ATX12V, which should also be installed (not all motherboards have this extra connector). You may need to lift the motherboard in a 45º angle with the table you are using to assemble your PC, since usually the wires from the power supply aren't long enough to reach the motherboard while it is on the table outside the case.
imageview.php?image=632
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | AMD Athlon 64 X2 4600+, 2.4 GHz...
External Harddrive does not work
Hi:
Hitachi hard drive are junk they are poorly made, but here is an option the could by a bigger hard drive and install it in the External case they are all the same, first take out the old HD from the case and take it with you to the store and purchse the same connection type wether its IDE or Sata and install it in the case, the cases are universal and all most all 5-1/4 inch HD will fit in the case is does not have to be A Hitachi Brand any brand will fit, I recommend a Seagate HD.
Apr 21, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I need to format the hard drive using vista
ok follow this steps now. 0. Configure your BIOS and select DVD/CD ROM Drive, SATA or IDE for the first booting of the system. 1. you should have CD/DVD ROM SATA or IDE. Any of it you can use for the operations, and it's should be attach on you system unit. 2. When you are done on step 1. You can now Enter the Vista DVD/CD Disk Installer inside the CD/DVD ROM SATA or IDE. 3 Restart your system unit to proceed to the operation. 4. Automatically the system will launch the Operating System Files and it will Record all your information inside your hard disk.
Apr 10, 2010 | Compaq Presario CQ60-220US PC Laptop
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Hard disk siz problem
Use Partition Magic to parition and format the hard drive.
Apr 26, 2009 | Seagate 750GB ST3750640AS SATA300 16MB...
Open Questions:
Western Digital imicro IM35ST320SI 3.5 IDE HDD External Enclosure and WD250G SATA Hard Drive Logo
196 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
